home sprayed epoxy primer
I was thinking of doing a black epoxy primer paint job on my truck has anyone sprayed at home in the garage and how did it turn out. I was looking to leave it in primer
Re: home sprayed epoxy primer
epoxy has no uv screeners. The sun will deteriorate it over time. Best bet is to buy some preflated single stage. You're local jobber can do this or you can go to hotrodflatz.com and get any color you want.
PPG also has a pre flattened clear that works well, DCU-2060.
i used o reillys primer.. its nason urethene (spell check) and with that and activator it was $99.88 went to harbor freight and bought a $15 gun.. sprayed it.. i got dry spray on it but its good enough..
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
and a few others
This is what I used. $64 / gallon at the local Fisher Auto Parts franchise. I think it turned out okay. I'm still putting it back together and the sign painter was just here yesterday.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
did you reduce that with acetone or add any catalyst? i've heard of people doing it both ways. looks great!
and a few others
No, just 4 to 1 thinner, and thanks.
You can definately get good results in your garage, but it depends more on you. Your prep work & gun control will have much more to do with your results than where you spray it.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I think your garage job will be fine. There are some Hispanic gentlemen here in Ft Worth that paint on the gravel in front of their shop. Their work surpasses what most guys can turn out in a high dollar booth. Keep the dust down and do good prep work.
check this one out found it on another forum cause i was thinking of doing something similar . It's all done with krylon satin black . 6 cans
One day.....
Rustoleum sells satin black in I believe quart and gallon sizes that you can find at home depot. They also have flat and other satin colors. I've used it with spray gun. Works well.
DZL1. |
I primed my old 89 chevy truck [5.3 4l60e] with some white PPG about a year to year and a half ago . It has been outside since my dad brouhgt it around the shop to wash it yesterday and it is holding up perfectly. Jim
#13 |
Just make sure your not breathing the stuff in, I would rather paint outside and have to sand off a few flies, then cough up my lungs.
#14 |
#15 |
Here's mine, tinted epoxy with a white base coat stripe.
#16 |
SLOW BUT SURE,BUT CLOSER
Did mine usin' epoxy, turned out good.
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... ![]() ![]() ![]() |
