Old 07-20-2009, 07:18 PM   #1
joedoozer
is Certifiable
joedoozer's Avatar
Turn Signal Switch
Coming home from work today I broke the turn signal switch on my truck. I have a 72 C10, non-tilt, auto on the column.
I got the wheel off, the little aluminum hub off too. I got all the way down to the switch itself, and can't seem to get it out. The arm is off, and the screws are out, but I can't get the switch out because it is caught because of the hazard button and the center shaft in the column.
Do I need to pull that whole part of the column off off the shaft? The bearing looks to have seen better days. It will be fine, if I don't mess with it.
So I want to get as much info on this before I make a bad day into a worse one.
Thanks for the help in advance.
1972 Chevy C10 LWB 350 Auto
Blue with a white roof.
joedoozer is offline   Reply With Quote
Old 07-20-2009, 07:23 PM   #2
JimKshortstep4x4
Re: Turn Signal Switch
If you depress the hazard button it will help your situation.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-20-2009, 09:48 PM   #3
joedoozer
is Certifiable
joedoozer's Avatar
I tried that but it was a real tight fit. I figured there had to be another way, so I stopped. I pick the new switch up from the store tomorrow, so I will give it another go. Thanks
Old 07-20-2009, 09:57 PM   #4
1967C20
Junior Member
1967C20's Avatar
Did you unscrew the hazard button from the switch? After unscrewing the button you should be able to depress the hazard switch just enough to slide it out. No need to disassemble the column.
"A man's got to know his limitations." - Dirty Harry
_______________________________________________
1967 C20 Custom Camper, 327, Powerglide, PS, PB, No-Spin Locker
1967C20 is offline   Reply With Quote
Old 07-21-2009, 07:38 AM   #5
joedoozer
is Certifiable
joedoozer's Avatar
I thought to unscrew it haha. It is the same color red as the plastic part inside the column, I just figured it was one piece.
Old 07-21-2009, 09:15 AM   #6
mr48chev
mr48chev's Avatar
They have always come right out for me with maybe a bit of wiggle work. I need to replace the one in my truck now as the hazard switch is broken and the switch won't cancel on one side most of the time. You did take all of the screws out? I think there are three that hold it in.
Also if you just broke the cam (the part that moves with the lever you can buy that separate and not have to replace the whole switch. Saves a stack of bux.
Old 07-21-2009, 10:36 AM   #7
69GMCLonghorn
69GMCLonghorn's Avatar
Jim
So try something like this, "You are the dumbest, most useless hazard button I've ever seen!" (You said depress it...)
69GMCLonghorn is offline   Reply With Quote
Old 07-21-2009, 11:55 AM   #8
red71c10
The Red Menace
red71c10's Avatar
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 07-21-2009, 02:36 PM   #9
71tahoe
71tahoe's Avatar
Original hazard buttons weren't screw-in. The new one will likely be a screw-in though. The biggest problem I had with the switch coming out was the wiring and plug.
71tahoe is offline   Reply With Quote
Old 07-21-2009, 03:12 PM   #10
joedoozer
is Certifiable
joedoozer's Avatar
Yeah the original hazard button is a red one, it does not unscrew. I will try again tonight to get it out. But other than yanking the top bearing out, I don't see this thing coming out.
Old 07-21-2009, 05:24 PM   #11
joedoozer
is Certifiable
joedoozer's Avatar
Switched replaced, not as bad as I thought. Just needed to take a break and go at it again with a clear mind. Just need to get a new steering wheel nut, since the guy that owned the truck before me destroyed the end of the column.
