Old 07-20-2009, 09:33 PM   #1
Big_Chevy_man
help
is there any companys that make a crankshaft pulley spacer kit mine sits about a 1/8 inch to far back to line up with the alternator and water pump if there is i would like a part # and company its a 74 chevy 350 if that makes a differance thanks
67 chevy lwb
soon to have a gmc front clip
Big_Chevy_man is offline   Reply With Quote
Old 07-20-2009, 10:30 PM   #2
Rack Man
Re: help
Yep...Moroso....Summit has them...I've used them. they work great!
http://www.summitracing.com/parts/MOR-64031
Dan
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 07-21-2009, 01:43 PM   #3
mclairmo
Re: help
You can also cut your own out of sheet metal and stack them to get 1/8 inch.
mclairmo is offline   Reply With Quote
Old 07-21-2009, 03:45 PM   #4
Skirkpat
Skirkpat's Avatar
Re: help
do not pull the harmonic balancer out an 1/8 of an inch?
(Sarcasm was lost in translation, Sorry for the confusion)
1969 Short Stepside
1969 4 WD Suburban
1970 1 Ton Dually....Misfit
oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door
Skirkpat is offline   Reply With Quote
Old 07-21-2009, 04:18 PM   #5
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: help
Originally Posted by Skirkpat View Post
Why not pull the harmonic balancer out an 1/8 of an inch?
I don't think that's a good idea. The center bolt tightens up aganst the pully and balancer. So, I think the bolt won't be tight.
It's strange that it doesn't line up.
Last edited by LOW DOUGH; 07-21-2009 at 04:19 PM. Reason: can't spell and there are probably still mistakes
LOW DOUGH is offline   Reply With Quote
Old 07-21-2009, 05:00 PM   #6
mclairmo
Re: help
Must be kidding, right? Do not loosen the balancer and pull it out 1/8 inch. It may eventually fly off the crankshaft nose and launch itself through your hood and or radiator.
Old 07-21-2009, 07:18 PM   #7
Rack Man
Re: help
The spacers work great.....a 1/16" spacer did the job for me...and I thought mine was going to need like 1/8 or more originally as it was way off.....
Look closely and you can see the spacer....
Old 07-23-2009, 05:25 PM   #8
Big_Chevy_man
Re: help
i might just make them they r just to expencive for a few thin peaces of steel
is a 67 gmc front clip for 300 a good price it comes with fenders grill and radiator support and maybe the wiring harness
67 chevy LFS
soon to have a 67 gmc front clip
Old 07-23-2009, 07:19 PM   #9
mclairmo
Re: help
$300 is good if no rust.
Old 08-06-2009, 02:15 PM   #10
Big_Chevy_man
Re: help
ok so i got it almost all put together i just got 1 of my last parts it its mr gasket part #1272 its for the oil filter isnt there some thing thats supposed to go between it and the filter??? if not i have the wrong part hoping to have my truck running soon will put pic up when its all set and running down the road
67 chevy swc lwb
soon to have 67 gmc front clip
