Old 07-20-2009, 10:16 PM   #1
wigadore
wigadore's Avatar
1949 GMC Radiator
I have a 1949 GMC Pickup project and I am in the need of a radiator that fits the stock core mount that will cool an LS1 and 700R4 Tranny. I have been told that the Chevy Rads are a different size and will not fit...hence all the rads I have found I need to modify. Does anyone know of a business that will custom build a unit to the right dimensions for this model of truck.
Thanks in advance
wigadore is offline   Reply With Quote
Old 07-20-2009, 11:57 PM   #2
OrrieG
OrrieG's Avatar
Re: 1949 GMC Radiator
I think companies like Griffen do custom work, but at a cost. Do the GMC big trucks (1.5 ton up) have a larger radiator that fits the 1/2 ton supports? On my 59 Chevy I got a big truck radiator it is 1" thicker and about 1.5" wider but still bolts in the same location as the original one. With the sbc there is plenty of room between the radiator and fan so clearance is not an issue.
OrrieG is offline   Reply With Quote
Old 07-21-2009, 12:24 AM   #3
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
I've heard that 60's mustangs fit and also that 30's ford truck rads fit, but I don't know if they will hold up to an LS1. becool makes a direct replacement rated to 350 hp, with those your spending a lot of money.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 07-21-2009, 07:39 AM   #4
Atomsplitter
Atomsplitter's Avatar
I bought my rad. on eBay that I put into my '48. It cost me about $300, it's sized for 600hp and it fits well simply by mounting it at the aluminum angle welded to the rad. I had to mount it at the back of the rad. frame because it is too thick to fit inside. I had no clearance issues but as you can see from the picture it's pretty close.
If your wondering about the hose that attaches to the top centre of the rad., thats my hot water relief for the backside of the LT1. It has reverse flow cooling and there's a hot spot near the passenger side rear of the motor that effects the intake manifold seal and will make it leak with long term exposure to heat. The rad. hose inlet was moved to the side by a welder friend of mine because the water pump discharges on this side and my air intake hoses would otherwise have been in the way.
Tonight I'll try to get the company name, I know the're in Michigan.
P.S. = Just as a heads up, I had questioned in various forums regarding what size of overflow I needed to fit my rad./motor set-up and no one could tell me the size I needed based on experience or to calculate the volumetric expansion of the water. The nice chrome coolant overflow I bought is too small a volume for this size of radiator. Mine is 15" long, I should have either bought the 18" long or at least a wider one. Hind-sight is wonderful.....keep learning from my mistakes!
Atomsplitter is offline   Reply With Quote
Old 07-21-2009, 04:58 PM   #5
54 jimmy
54 jimmy's Avatar
nickp51chevy is right the 60 mustang rad is what i plan to put in my truck. it all depends on if my orignal rad can be fixed.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 07-21-2009, 06:04 PM   #6
Atomsplitter
This Desert Cooler 47-55 V8 rad. is currently up for sale on eBay for $275....2 days left.
http://cgi.ebay.com/ebaymotors/1947-...A1%7C72%3A1171
Old 07-21-2009, 08:06 PM   #7
Atomsplitter
I bought mine ($350) from http://www.superiorradiator.com/ in Clemens, Michigan. If you check them out on the internet you'll find most people dealing with them are happy but there seems to be an issue with getting people their stuff in a timely manner. It took me 3-1/2 weeks to get mine and about 5 phone calls but it is nice and works great.
Good Luck
Old 07-21-2009, 09:53 PM   #8
wigadore
wigadore's Avatar
I found some cool rads at becool.com but OUCH the price. Of course I am in Canada and so the cost of this has to go up as most parts have to come in from the US. a Rad built by these guys for my exact truck is $852 CDN with a tranny cooler (auto), Dual Core, and an Electric Fan. Dimensions are total 23" wide 28" tall. I measured and this is an exact fit.
Atomsplitter Thanks for the links on ebay and the supplier you bought from. I will look into these as well. What did you unit cost roughly?
I looked at the 60 Mustang rad and it looks like it is the right shape, but it is too small width and height and it is only rated from what I have seen at 300HP. I need a max of 400HP with what is planned for this unit so I am not sure this application will work.
I saw this rad on the forum and I fell in love with it,
http://67-72chevytrucks.com/vboard/s...=206021&page=6
but of course the company is not being the easiest to work with. http://www.prchotrod.com/
Perhaps that is due to the cross border shipping issue I run into ALOT!
Old 07-22-2009, 06:57 PM   #9
pgf545
pgf545's Avatar
We bought ours from PRC Hot Rods. They build a great piece but are probably going to be a little more expensive than an EBAY unit. Take a look at my build thread for some pictures. Their web site is prchotrod.com
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 07-22-2009, 08:43 PM   #10
Atomsplitter
Wigadore,
I paid $350 last winter (2008) for the rad., it has the integral tranny cooler included.
Man, that is one cool rad from PRC...it looks like a piece for a show truck!
Old 07-24-2009, 08:00 PM   #11
wigadore
wigadore's Avatar
I have a quick link to the thread of pgf545 and I must admin I wish I had the experience he has to get my truck done. His thread shows me what I can do with a little elbow grease and some nice products.
Old 07-24-2009, 09:04 PM   #12
pgf545
pgf545's Avatar
Thanks for the compliment...I don't know if it is experience of just plain crazy. I think sometimes I have lost my mind. It started out as just installing a Mustang 2 setup and it has turned out becoming a monster...lol. It has been a lot of fun though and hopefully sometime in the next year we can get it drivable. i only get a few hours a week to mess with it. My dad just retired so he has been doing some work on it during the week.
Bernie
Old 07-24-2009, 10:37 PM   #13
CAL 58 GMC
CAL 58 GMC's Avatar
Bernie
I bought the same radiator from PRC after seeing Bernie's. It's very well built, but it's not cheap. They custom build them for you. I added the shroud, A/C condenser and they polished it, the price came to $1,000, but man it sure is nice and cools really good. Last week it was 112 degrees and my truck ran at a steady 180 in stop and go traffic. Here’s the link to there site http://www.prchotrod.com/
CAL 58 GMC is offline   Reply With Quote
