07-20-2009, 10:57 PM | #2 |
Re: got a light?
I thought they were for the bright lights
07-20-2009, 10:59 PM | #4 |
Gettin It One Pice At A Time
Re: got a light?
fog lights?
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
07-20-2009, 11:08 PM | #5 |
6.0 powered square
Re: got a light?
when the high beams are engaged the top and bottom lights are supposed to come on, are the bottoms lights even wired up
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
07-20-2009, 11:18 PM | #6 |
huh ???
Re: got a light?
Low beam = top lights
High beams = all 4 lights
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
07-20-2009, 11:18 PM | #7 |
Badass
Re: got a light?
yes there are i dont know where the bottoms wires run too?
but my high and low beam are done by the top lights
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
07-20-2009, 11:41 PM | #9 |
Re: got a light?
they might be burned out?
07-20-2009, 11:50 PM | #11 |
Happy to be here
Re: got a light?
07-20-2009, 11:52 PM | #12 |
Re: got a light?
it seems to have been said a few times, and i hope i dont seem like an ass, but when u have your lows on, just the top two work, when you have highs on all four turn on, meaning when you switch to high beams your tops can still be on even if the bottoms are burned out
07-21-2009, 12:00 AM | #13 |
Badass
Re: got a light?
thanks but i get that.
what is happing is...my top lights are acting like both high and low beam.so when i turn my highs on the top lights get brighter and the beam of light moves up i know how it should, but this is what i got
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 Last edited by 3r!c84; 07-21-2009 at 12:01 AM. |
07-21-2009, 12:05 AM | #14 |
huh ???
Re: got a light?
The top lights are doing exactly what they are made to do...
07-21-2009, 12:08 AM | #15 |
Badass
Re: got a light?
oh.
so the top should work as high/low and the bottoms should come on only when the highs are on?
07-21-2009, 12:12 AM | #16 |
huh ???
Re: got a light?
Yup
07-21-2009, 12:57 AM | #18 |
Re: got a light?
Yeah, the upper light fixture has 2 elements in it...1 for low beam and 1 for high beam. The fixture has 3 electrical posts on it where the high beam fixture will only have 2 electrical posts because it only has 1 light element in it. On high beam the secondary filament in the upper fixture illuminates as does the single filament in the lower fixture.
Sounds like you have just got 2 burned out lower fixtures. I would get a test light and check power at the lower light plug before buying new lights though, as they probably won't be returnable if the light isn't the issue. Good luck! |
07-21-2009, 01:13 AM | #19 |
Re: got a light?
My 84 Blazer did the same thing. I found out the bottom ones were burnt out. They are made to have all 4 on for high beams.
This is my best friend |
07-21-2009, 01:24 AM | #20 |
Badass
Re: got a light?
yea im going to get the good ol volt meter out and see if i got power going to them.
and you say the lights are returnable ?
07-21-2009, 01:40 AM | #21 |
Re: got a light?
Ummm...negative, as they are an electrical item, most parts stores won't take a return of them.
07-21-2009, 09:14 PM | #22 |
Badass
Re: got a light?
yea i got no Continuity on the lights.how many volts should be going to the light? i got 10.5 ish.with the motor off.
and a full battery
07-21-2009, 11:12 PM | #23 |
6.0 powered square
Re: got a light?
is that at the switch or the headlights
07-21-2009, 11:53 PM | #25 |
6.0 powered square
Re: got a light?
10 sounds about right
