Old 01-07-2003, 04:33 PM   #1
71GMC 4x4
700R4 Question
I have a 71 GMC 4x4 with a th350. How hard would it be to put in a 700R4? I have a 205 trans. case
[IMG]http://mustangmods.com/publish/topless99/truck2.jpg[IMG]
71GMC 4x4 is offline   Reply With Quote
Old 01-07-2003, 05:24 PM   #2
79Silv4x4
Workaholic
79Silv4x4's Avatar
Ask the guys at http://www.700r4.com
1979 K-10 Silverado (work in progress)
1991 V1500 Subruban
1999 Suburban LT 4x4
2006 Suburban LTZ (daily driver)
79Silv4x4 is offline   Reply With Quote
Old 01-07-2003, 07:53 PM   #3
breeh
Recovering 67-72 Addict
breeh's Avatar
It is a fairly simple exchange. I did it in my stepside. You just need to make sure that you put in a shortened trans shaft which is available from Advance Adapters. It will then bolt right up to your TH350/205 adapter.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 01-07-2003, 08:59 PM   #4
71GMC 4x4
What about the crossmember, did you have to move it?
Old 01-07-2003, 10:20 PM   #5
breeh
breeh's Avatar
Yes, I did have to move the crossmember. I did a few changes at once so I knew that I would have to move it. I put in a BBC and moved the engine crossmember forward to move the distributor away from the firewall. I also changed from a rockwell TC to a 205. It is easy to move and redrill the TC crossmember. The hardest part is figuring out where to drill the holes for the TC stabilizing mount on the passenger side.
