Old 07-21-2009, 01:34 AM   #1
Hazieview
Building Dreams out of Dimes!
For all the Small Block 400 Guys!!!
Hey guys I have recently stripped my sb400 down to the block. This is the rebuild I am considering with the AFR Aluminum heads.
http://www.popularhotrodding.com/eng...ine/index.html
The reason I like these heads so much is that you can run on low octane fuel and still have big gaines. My question is this.....
How effiecient is my engine going to be?
I know horse power and fuel mileage dont mix but I dont want to be getting 5 miles to the gallon. If that was the case I'd be getting a big block.
Also is it even worth building or should I invest in something else for the money to power ratio?
Waht do you think?
Hazieview is offline   Reply With Quote
Old 07-21-2009, 09:28 AM   #2
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
Re: For all the Small Block 400 Guys!!!
i love the 400 sbc but i have no clue about ur question
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 07-21-2009, 10:29 AM   #3
78BO
78BO's Avatar
I'm looking at these heads for when my warranty is up. Right now I have a 383 with vortec cast heads. It dynoed 405 hp at the crank. But I've seen a few sets of topend kits that put out 460hp with just a basic 350 block and 8.5/1. I would be willing to bet with my built bottom and these heads and cam I could be close if not over the 500hp range. But that's got to wait lol, too many pies in the oven right now.
78BO is offline   Reply With Quote
Old 07-25-2009, 09:47 PM   #4
crossy
Oh,you can't buy that new
crossy's Avatar
fuel mileage depends a LOT on where your sweet spot is on the curve and getting that particular RPM through gear ratios. Spread bore carbs are a big benifit too. 400's are not known to get good fuel mileage. remember big blocks started at 396 CID.
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 07-25-2009, 09:54 PM   #5
pokethesmot
so is a 400 a sbc or a bbc
Old 07-25-2009, 10:00 PM   #6
3r!c84
Badass
3r!c84's Avatar
SB! lol its a big small block.
the easiest way to tell is look at the header or manifold
BB all 4 are sped out . SB the middle 2 are close
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 07-25-2009, 10:02 PM   #7
tvblazer78
Low & Fast!
tvblazer78's Avatar
Small Block..
tvblazer78 is offline   Reply With Quote
Old 07-25-2009, 10:03 PM   #8
dammitmitchell
the pollock
dammitmitchell's Avatar
that's why it's called a SBC 400 pokes...
goober..
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 07-25-2009, 10:05 PM   #9
3r!c84
Badass
3r!c84's Avatar
lol this is what confused him :remember big blocks started at 396 CID.
-00 Saturn 5spd
1/4:13:90
Old 07-26-2009, 10:25 AM   #10
manimal
manimal's Avatar
400's a great engines,EXCEPT for the 4 bolt mains. They are known to crack in the main webs.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 07-26-2009, 11:43 AM   #11
LONGHAIR
I think that the real confusion came from Chevrolet.....They call the Big Block engines that they put into the 67-72 generation of trucks 400...even though they were actually 402.
IIRC they did the same thing in "low performance" big body boats (Impala, station wagons, etc)
396s and 402s were only used in preformance oriented cars....Camaros, Chevelles, Corvettes, Novas, etc....
The small block version of the 400 was used mostly the same way, big tanks that needed the torque to get them moving, not really in Hi performance cars.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-26-2009, 12:02 PM   #12
Manbearpig
Manbearpig's Avatar
Nope 366!
1972 GMC C10
Manbearpig is offline   Reply With Quote
Old 07-26-2009, 12:13 PM   #13
pokethesmot
yeah lol
Old 07-26-2009, 12:15 PM   #14
pokethesmot
man thats good cuz my truck is a tank lol
Old 07-26-2009, 12:19 PM   #15
Albatrossian
Georgia Boy
Albatrossian's Avatar
Getting good mileage doesn't consist of just the engine. It also depends on transmission, rear gear ratio and vehicle weight. Also remember that 405hp at the crank is NOT the same as 405 at the wheels. You can lose as much as 100hp just from parasitic loss through the driveline. Also remember that 400s, while they are good engines, are prone to cooling issues because of the lack of steam passages. If you're going to use the 400, make sure your cooling system is up to par or you will have problems.
81 GMC High Sierra, 2WD, 357ci/700R4, 3.73s, posi.
Albatrossian is offline   Reply With Quote
Old 07-26-2009, 12:27 PM   #16
Chlsnk
Chlsnk's Avatar
Actually didnt the BBC start at 348cid?
Chlsnk is offline   Reply With Quote
Old 07-27-2009, 05:26 AM   #17
crossy
crossy's Avatar
the 348 and 409 are usually referred to as 'W' motors due to valve cover design.
big trucks had big blocks as small as 366 CID
passenger car big blocks started at 396, 402,427 & 454 and in 69-72 trucks and 70-72 big cars ,for some unknown by me marketing reason, they called the 402 big block a 400 big block in everything BUT the Chevelle, Nova & and Camaro where it was still called a 396 instead of a 402. SS396 just hada good 'ring' to it.
98 Vortec project.
94,3500,6.5L 4L80
Old 08-02-2009, 06:12 PM   #18
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
Cool Re: For all the Small Block 400 Guys!!!
I am in COMPLETE agreement with this statement!!!
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 08-02-2009, 06:26 PM   #19
clinebarger
ive had 2 400 sbc both cracked the lower row of head bolts but the nitrous might have had somthing to do with it. and the short rods dont help either. if your really serious about having a 400+ ci small block invest in a bowtie block.
clinebarger is offline   Reply With Quote
Old 08-02-2009, 06:29 PM   #20
RPOZ11
RPOZ11's Avatar
MoTown & DART would be suitable cadidates as well
HO72 build :
2017 SS
Old 08-02-2009, 06:33 PM   #21
clinebarger
Yes sir they whould.
Old 08-02-2009, 06:35 PM   #22
aaronschendel
I build a 406 in my garage two years ago. I am using World Sportsman II heads and I used a longer rod. It's a major torque monster. I had the block drilled for steam holes when I had the machining done. I ran it for two years with the stock cooling system with never an overheating issue.
I just ran it about 1,000 miles after swapping in a new cam and driving 70-75 I returned about 13 miles per gallon. It gets better the slower you drive but if you are using it like it should it's not terrible.
aaronschendel is offline   Reply With Quote
