07-21-2009, 09:32 AM | #1 |
HD Suspension drop?....
Ive been looking.. Cant seem to find the answer...
I have a 79 GMC with the HD front and rear suspension, it is a 2wd truck. Just woundering what kits are perfered by you guys, Im not looking to "Bag" or "Airride" it... just a simple drop. Something to give it a lil Hot rod look? Oh pics of 79ish trucks dropped too... Inspiration... Thanks
Static Dropped 1988 Chevrolet ECLB "Hovering less then 3 inches from the ground... full-time" |
07-21-2009, 09:39 AM | #2 |
Happy to be here
Re: HD Suspension drop?....
What size tires are you going to run? I normally recommend a 5/7 drop but it depends on the height of the tire you want to run.
07-21-2009, 01:31 PM | #3 |
6.0 powered square
I had a 6/5 or what ever it was
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
07-21-2009, 03:39 PM | #4 |
I plan on running 235/70/15... I have 235/75/15's on it now...
So the HD front suspension is typically the same as a standard... just a HD coil spring is all? On the rear I have 6 leafs... I guessing I have to remove some and set in a helper leaf? Im using this to tow... so that is why Im ask is all... Flamingbig10... that is a nice truck... Im trying hard not to do flames this time... going for the old guy scheme... 2tone
07-21-2009, 04:34 PM | #5 |
6.0 powered square
thanks diamond, the heavy duty packages would be a heavy half it came with larger front and rear brakes heavy duty coils, at least 6 leafs and a12 bolt rear end and any lower component will work if you get spindles you will need ones for 1 1/4 brake rotors if you want to tuck tires I would with a 5/7 if want to a little gap between the top tires and fender wells go with a 3/4 drop
07-21-2009, 05:00 PM | #6 |
3/4 drop is what Im looking for.. nice and suddle...
Thanks for the info... Im trying to read up on dropping the front... Ive done cars.. but trucks.. my first.. heck I havent a clue what a spindle is.. but Im looking... I will get there I have plenty of time... And this is the truck I had... with the 22" wheels.. drop wasnt in the plans... notice the suddle flames.. I cant seem to get away from them.. keep popping up on every thing I own.. I had to sell this after I lost my job... and now I have my car about to be repo'd... But the GMC is free and clear ride...
07-21-2009, 07:36 PM | #7 |
6.0 powered square
here what a spindle looks like
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by N2TRUX; 07-21-2009 at 08:18 PM. |
07-21-2009, 09:27 PM | #8 |
Oh.. thats what they were... I was actually thinking it was the a-arms... but that makes sence
Someone has a thread in the suspension catagory.. pictures of the process... Good timimg on this...
