Old 07-21-2009, 10:48 AM   #1
Bam Bam 56
Rear differential question
OK, haven't had a chance to get pictures yet, but i need some help identifying the rear end for my truck. I was told by several that it was a Dana 60, it is out of a 1970 C20 longhorn with leaf spring rear. I recently had the guy who's buying the cab from my organ donor over and he said he didn't thing it was a 60. I have researched identification but can only find info to id a Dana 44, which has 44 cast into the ribs. I have no such markings for a 60. It is a 10 bolt with a 3rd member like a Ford 9 inch has. It has 8 lug drums. I don't see many markings on it as far as PN or anything, but i don't have the entire thing cleaned up yet either.
Any idea's?
Chris "Bam Bam" Shields
Little Chute, WI
1970 Chevy Longhorn C20 in progress
2007 Chevy Vortech MAX - every day beast
Project Longhorn
Bam Bam 56 is offline   Reply With Quote
Old 07-21-2009, 10:59 AM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Rear differential question
Sounds like an Eaton HO52. Is the cover round?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 07-21-2009, 11:02 AM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
It is definately an Eaton.
--Josh
Old 07-21-2009, 11:03 AM   #4
vectorit
What?
vectorit's Avatar
Here is a pic of Eaton, which sounds like what you have.
Does yours look like this?
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 07-21-2009, 11:08 AM   #5
Bam Bam 56
That does look like mine, not so sure my cover is that smooth though. I would have to confirm that. Mine might have a couple contours to it
Is there any concerns with the Eaton. The only thing that i know about them is that this one (if this one is an Eaton) has been pulling around full hay wagons and such for the last 30 years and never failed
Little Chute, WI
Project Longhorn
Old 07-21-2009, 11:20 AM   #6
Bam Bam 56
Just had my wife take pictures and send them to me. That is exactly how my rear cover looks. Any opinions on these. Loaded question, i know
Little Chute, WI
Project Longhorn
Old 07-21-2009, 11:34 AM   #7
69GMCLonghorn
69GMCLonghorn's Avatar
I've had 2 trucks with Eaton rear ends. The only thing I DON'T like about them is the highest gears you can put in them is 4.10. In terms of strength, if you break an Eaton, you're probably doing something you shouldn't be doing.
My first one my dad bought in '79 and drove until around '89 when I took it. My neighbor has it and works the CRAP out of it to this day. It has over 400,000 miles on the rear end and it's just like new...
69GMCLonghorn is offline   Reply With Quote
Old 07-21-2009, 05:01 PM   #8
vectorit
What?
vectorit's Avatar
My Eaton is the original in my 68 K20 burb, and most of it's life was spent pulling trailers. Never had a failure, they are leakers though... Takes a lot of care to get them to seal properly.
Mine always leaves it's mark in the garage.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 07-22-2009, 09:00 PM   #9
capev86
i am looking to swap out the 4.57FD in my 72 suburban (coil spring rear) for the 4.10 (any guys looking to mud bog or rock climb and stuck with the softer gear?). i plan to also install the OD unit on the saginaw 3 on the column. that combined with the stock size tall tires should be about equivalent to a 1/2 ton w/ 3.73 gears and OD and net me 17-18mpg trips from the ol' 307. i plan to tow trailers with my burb, so 4.10 is a good compromise. the 4.57 is terrible on the highway and 50mph is like 75 in a modern truck.
capev86 is offline   Reply With Quote
