53 gmc cab
I am looking at building a cart to put my cab on after I remove it from the old chassis. Does any one know what the appox weight would be for the cab off of a 53 GMC 9430?
Re: 53 gmc cab
About what two stout guys or 4 normal guys can lift? I would guess 300#with out doors, add 100# for the doors.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Re: 53 gmc cab
well thats not too bad. I thought it may be like 1000lbs. I saw an engine stand that I was going to use as a cart.
and a few others
Re: 53 gmc cab
My brother and I lifted our 54 cab off the frame, onto a trailer, delivered to the sandblaster, and put it back on the frame by ourselves. Just took two landscape timbers and ran them thru the door openings. Put one end on each shoulder and stand up straight. Then carry them wherever you want them. This was a stripped cab; no glass, no doors, no wiring, etc.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Re: 53 gmc cab
Check www.Stovebolt.com in the tech section they have a number of buildable tools to help out. good luck!
Re: 53 gmc cab
I saw a thread on here where a guy built a dolly out of 2x4s and looks like it worked quite well... I'll see if I can find it.
Re: 53 gmc cab
i used 2 furniture rollers i got from harbor freight for 20 bucks each. 3 work the best. 1 at the rear and 2 under the a pillars... do it cheep you probably won't need the cart as much as the furniture rollers ...
GT
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
Re: 53 gmc cab
Look at my thread. We built one out of 2x4's...it works really good. I think I have a couple of pictures of it on there with the cab sitting on it.
Bernie |
Re: 53 gmc cab
mattohc, i built mine out of 2x6's, 6x6 for the corners/legs and a sheet of plywood. Its a little wide. If I had to do over again I would cut the width down to 40 inches. Mine is very stout!!! 3 inch casters allow me to roll around really really easy. I have about 60 bucks total in mine.
"Get Busy Living or Get Busy Dying" 1970 P10 Stepvan |
