Old 07-21-2009, 02:48 PM   #1
Camper Power
Camper Power's Avatar
Oil Pan Removal
i know its possible with the engine still in the truck, just want to know if i have to lift the engine a bit for the pan to clear the cross member, and if i do do i need to remove the distributor, its an HEI. thanks
eh
1970 Chevy C20 daily driver
1975 GMC Jimmy 4x4 project
1966 GMC C10 Dad's project
Camper Power is offline   Reply With Quote
Old 07-21-2009, 03:10 PM   #2
smoky02
Location: Sunny, Florida, some might call it South Alabama
Re: Oil Pan Removal
I didn't...just unbolted my motor mounts and picked the motor up a little. getting it out was the easy part. Back in really sucked.
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 07-21-2009, 05:14 PM   #3
mclairmo
Re: Oil Pan Removal
If you have to lift the engine a little to slip the pan out, be sure to use a flat wooden board between your jack and the pan so you don't dent it and then unbolt the motor mounts and lift the engine. Check to be sure the HEI does not hit the firewall. Removing just the cap might give you enough clearance. Place 2x4 wooden blocks between the engine mounts and the frame brackets and lower the engine back down. Make sure the oil pump pick up is clean inside and has not wiggled itself loose. May want to make sure oil pump is not worn out while you have the pan off. Use a one piece rubber oil pan seal when you put it back on.
mclairmo is offline   Reply With Quote
Old 07-21-2009, 06:48 PM   #4
neonlarry
neonlarry's Avatar
Re: Oil Pan Removal
Also rotate the crank so timing mark is 180° out, this should give maximum clearance of the counterweights.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 07-21-2009, 10:13 PM   #5
dave2953
Dave's not here, man
dave2953's Avatar
Re: Oil Pan Removal
I also loosened the mounts a little and jacked the motor up. I have always had trouble clearing the flywheel without jacking the motor up. I have an HEI as well, but there's never been a clearance issue there...the fan shroud did have to come off, though. Good luck with it...it's one of my least favorite things to do on my truck. BTW, I second the one piece Felpro gasket suggestion.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
