Old 07-21-2009, 04:44 PM   #1
Jblackie47803
'67 Heavy Duty Rear Coil option
The guy I got my truck from many years ago referred to it as a "heavy half-ton" The option sheet indeed lists it as having a heavy duty spring. Is this common? Rare? It is a half-ton with 6 lug wheels and coils at all four corners.
Jblackie47803 is offline   Reply With Quote
Old 07-21-2009, 04:58 PM   #2
mclairmo
Re: '67 Heavy Duty Rear Coil option
I have not seen this option before but I assume it is merely a higher rate coil spring maybe closer to a 3/4 ton spring rate.
mclairmo is offline   Reply With Quote
Old 07-21-2009, 05:32 PM   #3
Skirkpat
Skirkpat's Avatar
Is it a helper spring? I have seen some that look like a half of a leaf that clamps onto the frame behind the axle?
1969 Short Stepside
1969 4 WD Suburban
1970 1 Ton Dually....Misfit
oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door
Skirkpat is offline   Reply With Quote
Old 07-21-2009, 06:12 PM   #4
mclairmo
I have seen the helper spring but I think the option sheet (SPID) lists it as "G60 auxiliary rear springs". The G50 option, as in this case, is just a heavier rate coil spring.
Old 07-21-2009, 08:50 PM   #5
68 Stepside
huh?
68 Stepside's Avatar
I'll have to look at my 67 Panel's option sheet. I think it listed heavy rear springs, and it had the "helper" spring attached to the frame, which would rest on the top of the axle under a load.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 07-21-2009, 08:52 PM   #6
faribran
i have a 67 with this same option..
like urz, this one had few options.
these springs make the rear higher than normal
faribran is offline   Reply With Quote
Old 07-21-2009, 08:54 PM   #7
68 Stepside
huh?
mclairmo is right. G50 heavy rear spring is just a higher rate coil spring. My panel had the G60 "auxilliary rear springs" option, which was the helper leaves. My bad.
RIP El Jay
Old 07-21-2009, 08:59 PM   #8
Shyguy
Junior Member
Shyguy's Avatar
The rear coil springs on my '71 lwb stepper has the heavy duty option and no helper leaf springs.
It came with a 350 and compound 4 speed.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 07-22-2009, 05:29 AM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it is a 3/4 ton spring from the factory.
Does not make it a 3/4 ton truck though, still a lame rear end.
the PO was wrong on calling it a heavy half. That was an option package in the late 70's.
