Old 07-21-2009, 05:50 PM   #1
CaptMadDog
frame rail pics
for the guys who have done frame offs of your trucks im looking fo pics sighting down the frame front to back and then back to front if you have them. im trying to see if what im seeing on mine is correct. thanks
My build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=348729
CaptMadDog is offline   Reply With Quote
Old 07-21-2009, 09:01 PM   #2
truckpoorpackrat
Re: frame rail pics
I notice from your build thread you think your frame is bent. Have you cross measured it ? What part do you think is bent ? Do you have any friends who work in a body shop ? Will help what I can. James.
truckpoorpackrat is offline   Reply With Quote
Old 07-21-2009, 09:17 PM   #3
69_C10
Doing it my damn self.....
69_C10's Avatar
Re: frame rail pics
I have pics of my frame off project that I'm currently working on in my build thread if it helps. Check it out and Good luck.
Mark...
Project 69 Stepside...http://67-72chevytrucks.com/vboard/s...d.php?t=290761
69 C10 Stepper - Current Build
94 Silverado - Driver
05 Hummer H2 - Unique Whip
69_C10 is offline   Reply With Quote
Old 07-21-2009, 11:50 PM   #4
CaptMadDog
Re: frame rail pics
yeah got one quote on getting it done today that quote was 400-500 lol that was suppose to be discounted too cause my friend is frends with the guy lol.
so we called up another shop and a guy is coming over tomorrow to look.
thanks for your replys i was just seeing how far out my frame was and its pretty tweaked one rail is slightly pushed back and twisted the other is twisted and bent.
Old 07-22-2009, 12:12 AM   #5
mr48chev
mr48chev's Avatar
Re: frame rail pics
It's hard to second guess what someone is doing on his project but my question is why didn't you hunt down another frame when you discovered that yours was bent?
Although 500 doesn't sound too bad for having it put on a frame machine and having it put back right. I wouldn't do any modifications until I got it back though as getting it squared away may change the position of where the C knotch goes or other the alignment of other pieces.
A quick check for square with a tape measure on matching points on the four corners will tell you if it is out of square.
Old 07-22-2009, 01:11 AM   #6
CaptMadDog
Re: frame rail pics
un fortunately i already welded my c notches in but they shouldnt b too far off i measured from points on the frame for the right axle placement.
and as for getting a new frame ive looked and swb frames in my area are few and far between. (watch ill find one on CL after i post this lol)
thanks for your input i appreciate ur opinions as alot of what u guys have to say i wouldnt think of.
thanks!!
Old 07-22-2009, 06:42 AM   #7
truckpoorpackrat
Re: frame rail pics
If the quote of 400 to 500 dollars included setup & measuring it with a digital measuring system then that's not to bad. Frame rate in my area is $65.00 per. hour, yours is probably more. Can you point out the area that is the problem ? If it is on the very front it should be easy to fix, if it is in the center right in front of the cab mount close to the front shock mount it will be harder to straighten & make it look perfect (the last picture where the broom is setting). You might check with KrazyRay if you are looking to replace it, sounds like he might have a few. James
Old 07-22-2009, 09:54 PM   #8
CaptMadDog
Re: frame rail pics
James im talking with a friend who has a shop hes gonna try to get his frame guy to do it on the side for me which should bring that quote down tremendously.
i will prob kno tomorrow and its bent and twisted at the front and middle but the guy seems optimistic about it.
Josh
Old 07-22-2009, 10:50 PM   #9
truckpoorpackrat
Re: frame rail pics
I hope all goes well, and he is able to fix it for you. Look on the bright side at least you noticed it was bent prior to painting or powder coating it. James
Old 07-23-2009, 11:35 AM   #10
CaptMadDog
Re: frame rail pics
very true!!! still hate the fact that its bent and not of my doing lol.
