07-21-2009, 06:02 PM | #1 |
i want some bodywork tips!
i have been interested in body work along time, and now i have a project that needs a bit. what are some of the steps, process etc that i should use to do this? i.e. what grit(s) paper, do i need to go to bare metal, what types of sanding techniques should i use, etc. any and all tips are very appreciated
72 c-10 lwb: mild 350 , turbo 350 w shift kit, 3.73, drop spindles and rear drop springs, e-fan, relocated fuel tank, roll pan, Progressive wheels, 02 silverado buckets&console |
07-21-2009, 06:28 PM | #2 |
I am a Referee of life.
Re: i want some bodywork tips!
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
07-21-2009, 06:34 PM | #3 |
with stripping all the way to bare metal theres a few ways... wire wheel, 36 gritt sand paper, ginder..ect.
When spreading filler make it as smooth as possible to make sanding easier... when applying filler your supposed to go to bare metal but glazing putty can be applied over a scuffed surface... sand in an X patter not up and down or side to side. when using a grinder hold it flat to not gouge the metal. when welding go slow... heat will warp panels... when working on say a truck fender have another project like the roof or bedside.. switch between the two so you don't burn out. Get a 5 Gallon bucket to sit on. fiberglass filler can make you itch. wear safty glasses and a dustmask. "You get what you pay for" don't expect cheap tools to preform well. when sanding filler start with 36 then 80 then 180 prime block with 180 prime wet sand with 600-800. MEASURE when making stuff or doing patch panels... Get a good pair of tin snips. "Durablock" is my favorite sanding blocks. there foam ones are amazing. Get some in various sizes. You can also use a paint stick wraped in sand paper. get your self a few body hammers... dont try to do body work with a claw hammer. If you thnk of any questions PM me. Last edited by Naterman35; 07-21-2009 at 06:34 PM. |
Tags |
body work tips |
