Old 07-21-2009, 07:14 PM   #1
crossy
Oh,you can't buy that new
crossy's Avatar
Fuel gauge wiring. problems
anyone have an idea what color wiring is coming up from the fuel sender to the dash on an 81. my fuel gauge buries when the key is on. I forget if that means totally grounded out or open circuit on a fuel gauge. I have to tackle one disaster at a time with this truck from the P/O . thanx , crossy
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 07-21-2009, 08:02 PM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Fuel gauge wiring. problems
I think tan, but let me find the schematics.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-21-2009, 08:06 PM   #3
glock35ipsc
Or maybe pink
Bob
Old 07-21-2009, 08:07 PM   #4
glock35ipsc
Here, I gotta go eat dinner.....
http://forum.73-87chevytrucks.com/sm...?topic=11766.0
Bob
Old 07-21-2009, 08:55 PM   #5
crossy
crossy's Avatar
link didn't work. crossy
98 Vortec project.
94,3500,6.5L 4L80
Old 07-21-2009, 09:00 PM   #6
glock35ipsc
Hmm, t's working here. Try CTRL F5, then click it again.
Bob
Old 07-21-2009, 09:57 PM   #7
oldgmc
oldgmc's Avatar
Link worked for me
oldgmc is offline   Reply With Quote
Old 07-21-2009, 10:45 PM   #8
crossy
crossy's Avatar
I got it, but the ground could be any of THREE colors. ??
looks like pink for power and thats what #18 on the cluster connection was. #18 runs to the fuel gauge ,but so does #16 and #10 which are both grounds on the cluster. i thought fuel gauges were nothing but a meter/needle hooked to a resistor. I don't get the three wires with two being grounds? thanx ,crossy
98 Vortec project.
94,3500,6.5L 4L80
Old 07-22-2009, 08:55 PM   #9
warpig98
so Crossy how you hookin urs up>
THANK YOU SOLDIERS!!!!!
VISIT MY 78 BUILD THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=334884
warpig98 is offline   Reply With Quote
Old 07-22-2009, 10:03 PM   #10
crossy
crossy's Avatar
I found those schematics. One problem. i don't see a dual tank set up.
ANYWAY the idiot P/o removed the right tank. it uses only the left, but the switch inside cab was busted, one pink wire cut then it was shoved behind the dash. there is a Lt. green , Dk. green, pink & black wire running to the switch. ANYONE have an idea what it takes to bypass the switch. I still have no gauge at this point.
My tank had the PURPLE ground wire and i removed it, cleaned , re-installed. No change in gauge even when removed. I then found the tan/white (not pink)power wire and the connector. no change when unplugged. hmmm .
I REALLY need to know i have bypassed the switch right before i troubleshoot anything else.
thanx,crossy
98 Vortec project.
94,3500,6.5L 4L80
Old 07-25-2009, 09:33 PM   #11
crossy
crossy's Avatar
well I havea working fuel gauge for the first time in ??? years. Too involved to explain, but i verified the sender was good with an ohmeter so i ran my own wire and spliced it in(correctly) to the 18 pin connector on the cluster.
THEN_ I found where the IPO had cut the pink wire. he used the fuse off the fuse box for the elestric fuel pump. I made things right. put fuel pump on a separate fused connection.
98 Vortec project.
94,3500,6.5L 4L80
Old 07-25-2009, 10:49 PM   #12
glock35ipsc
Nice!!!
Bob
