Old 07-21-2009, 09:50 PM   #1
hensonjd
6.0 Engine conversion NEED HELP FAST!
I Wass trying to drop in my motor into my frame but I cant get in with the ac compressor to go down in the frames. To narrow. What should I do? Cut the frame? Also how do I hook up the tranny its a 4l80E? Will the tranny need its own cooler? Also what headers are yall useing the? theirs no way to fit the stock ones. Thanks for any knowledge
hensonjd is offline   Reply With Quote
Old 07-21-2009, 10:24 PM   #2
smoky02
Location: Sunny, Florida, some might call it South Alabama
Re: 6.0 Engine conversion NEED HELP FAST!
If you search for ls1 style conversion, or check out the build thread all your answers will be answered. These are very common questions you are asking, and there is a bracket that you can pick up to move the a/c
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 07-21-2009, 10:38 PM   #3
hensonjd
Where do i get the bracket
Old 07-21-2009, 10:41 PM   #4
smoky02
I would say while you are reading the search that you have just completed, there are probably a few ideas in there.
Old 07-21-2009, 11:18 PM   #5
Hart_Rod
Hart_Rod's Avatar
What motor mounts are you using? I used ECE mounts and I had no clearance issues.
Hart_Rod is offline   Reply With Quote
Old 07-21-2009, 11:45 PM   #6
Blitz
Mr. Thread Killer
Dang. Nice headers.
Blitz is offline   Reply With Quote
Old 07-21-2009, 11:50 PM   #7
hensonjd
I also used the ece mounts. What are you gona use to run the lines off the compressor? Will the original lines fit?
Old 07-22-2009, 01:24 AM   #8
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Blitz View Post
Dang. Nice headers.
Thanks! They're Doug Thorley Headers.
No, the fitting that connects to the compressor is to big. You'll have to get something like this:
http://www.docsblocks.com/products.asp?cat=14
Old 07-22-2009, 01:47 AM   #9
hensonjd
How did you get rid of our egr stuff?
Old 07-22-2009, 09:52 AM   #10
Arad68
Trucks N Tranzams
Arad68's Avatar
http://www.kwikperf.com/
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 07-22-2009, 10:13 AM   #11
Hart_Rod
Hart_Rod's Avatar
Old 07-22-2009, 02:44 PM   #12
hensonjd
the stuff that was originally on the exhaust manifold on the passenger side. ON that link you posted. Which one of the acfittings do i need?
Old 07-22-2009, 03:12 PM   #13
Hart_Rod
Hart_Rod's Avatar
The headers came with out the EGR stuff. When I have my computer programmed, I'll have them remove the EGR circuit. I'm not sure which fitting to use yet, I haven't hooked that part of my AC up yet, but I know they will have one that works. Get back with me in a couple of months....
Old 07-22-2009, 05:33 PM   #14
Custom 68
Custom 68's Avatar
I had to install my compressor after the motor was in place. It is very tight and somewhat tough to get in place. I made my own motor mounts but it does sit down inside the frame. I bought fittings and had the hoses made.
dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 07-22-2009, 06:06 PM   #15
hensonjd
I got my motor mounted in today with the ac compressor on. Im now trying to figure out the rite angle for the tranny to be sitting and what to put under it.
Old 07-22-2009, 06:08 PM   #16
Hart_Rod
Hart_Rod's Avatar
What transmission mount are you using?
Old 07-22-2009, 06:09 PM   #17
68 short step
need someone to install it too? there are lots of threads that answer all your questions....plus some you havent thought to ask yet
68 short step is offline   Reply With Quote
Old 07-23-2009, 03:11 AM   #18
hensonjd
Im gona try to use the factory auto crossmember. Its tuff getting the bottom bolts in on the motor mounts. Thats taking me about as long as any thing else.
Old 07-23-2009, 10:08 AM   #19
Shon
I am using the stock trans X-member with stock rubber trans mount along with stock motor stands and poly mounts for the year model truck.
I had to drill one hole for the trans mount b/c the original mount had 2 bolts and the new one has 1 stud.
With the way mine is I was able to use existing holes in the frame.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 07-23-2009, 08:03 PM   #20
boostat4500
Yes the tranny needs it's own cooler, the bigger the better! What do you mean "how do I hook up the tranny"?
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc.
boostat4500 is offline   Reply With Quote
Old 07-23-2009, 09:16 PM   #21
hensonjd
I ges I mean does it need to be sitting at a certain degree of angle? and Im not sure what to use between the stock crossmember and the transmission to raise it up, Im sure their has been multiple threads for this but its tuff searching the threads. lol. This question goes out to all that used the ece mounts, how did yall install the bottom front bolts on the motor mounts I can not get anything to them from either side. thanks for all te great help.
Old 07-23-2009, 10:24 PM   #22
Hart_Rod
Hart_Rod's Avatar
Fuel injected motors can sit at any angle. I just used the stock 4L60E tranny mount. I didn't have any problems with any of the motor mount bolts, so I'm not sure what to tell you there........
Old 07-23-2009, 10:25 PM   #23
Shon
mine sits level at trans pan...
Old 07-23-2009, 10:30 PM   #24
Hart_Rod
Hart_Rod's Avatar
Pictures....
