Front disk
Hello all i would like to know if the front disk from a 67 c10 would fit on my 70c10. The kit is from cpp in southern calif. the only thing i am not getting is master cylinder an perportioning valve.
"Your trucks fast! You must have been going 120 when I passed you." "Owning A 10 Sec Import Is Like Coming Out Of The Closet, In The End Ur Still Gay" If for some reason i loose to a import...At least i can go home knowing the vehicle i drive drops girls panties... |
Re: Front disk
Yeah you should be good
70 SWB STEPSIDE 70 BLAZER 09 challenger |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Front disk
A 67 does not have front discs, it has drums.
Re: Front disk
you'll need both master cyl and prop valve from a disc/drum setup to have a properly working setup
Re: Front disk
Yes,it will fit and you just need the master cyl/prop valve.
