Old 07-22-2009, 11:00 AM   #1
au03z71
au03z71's Avatar
Question on pressure
I had my truck up on the lift and the bags up front inflated fine. However, when I got it down off the lift (Tank pressure around 80-90 psig) they would only lift about 1/2 way. When I increased my tank pressure (125-150 psig) the bags lifted fine. Is this too high for a tank pressure, and if so, what is wrong?
There are no leaky fittings/valves and everything looks to be operating properly.
au03z71 is offline   Reply With Quote
Old 07-22-2009, 12:28 PM   #2
SCOTI
SCOTI's Avatar
Re: Question on pressure
Tank pressure should normally be 125psi minimum or more (depending on what pressure switch you choose).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-22-2009, 01:16 PM   #3
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
That sounds about right. With only 80-90lbs of supply pressure it would take forever to equalize the tank and get the front up.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 07-23-2009, 10:16 AM   #4
bedsled71
bedsled71's Avatar
the size of your bags is also a factor. smaller bag = more pressure, the opposite with bigger bag
bedsled71 is offline   Reply With Quote
Old 07-23-2009, 10:52 AM   #5
au03z71
au03z71's Avatar
OK. That's kind of what I figured. I just wanted to make sure something wasn't jacked up with my system.
Old 07-25-2009, 10:28 AM   #6
Strodder
Daring to be Different
Strodder's Avatar
What size air tank, or tanks do you have? More air storage will help.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
