07-22-2009, 03:55 PM | #1 |
Restoration Virgin!
Serpentine Belt Setup Question
Hey Guys,
I talked to a guy that has a serpentine belt setup from a 1989 5.0 Throttle body motor in a Firebird. Will this work on my 1973 350 SBC?? Thanks
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
07-22-2009, 04:13 PM | #2 |
Under Construction
Re: Serpentine Belt Setup Question
They say it will. do you still have the link i sent you on the serp stuff. let me see if i have it handy.
EDit....... http://67-72chevytrucks.com/vboard/s...d.php?t=233335
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 07-22-2009 at 04:18 PM. |
07-22-2009, 08:33 PM | #3 |
Hollister Road Co.
I put a 91 setup on my 72. The right head does not have on hole for the upper bolt.
Don't forget the reverse direction water pump. |
07-22-2009, 09:34 PM | #4 | |
Restoration Virgin!
So looking at post #14 of the thread, this doesn't look to be a good setup to buy?!?!?
07-23-2009, 07:45 AM | #5 |
Restoration Virgin!
and for the pics....any thoughts please?!?!?!
07-23-2009, 09:09 AM | #6 |
Under Construction
They state they(car setup) are prone to breakage, and belt squeaks... I went with a '94 suburban/truck serp setup on the '67 and went with the GMPP serp setup on the '56 years ago.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 07-23-2009 at 09:09 AM. |
07-23-2009, 11:52 AM | #7 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-23-2009, 02:28 PM | #8 |
I have seen the two piece cast ones break. But they also have a one piece serp setup made of steel too. Only drawback is to install it or remove it requires removal of the water pump as the area around the water pump is mounted tightly around it. But it is steel not cast metal. On some surban's and GMC 3/4 T trucks, 92-94's 350's. Weak points seem to be around the alt. and the power steering pump.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
09-09-2009, 11:42 AM | #9 |
Never Ending Projects
Okay, I just picked up on of these systems from a S10 Blazer. Basically everything bolts up fine (outside of missing the one hole on the pass. side head, which I will drill and tap).
I ordered a A/C delete pulley from Rock Auto ($27.79) and went to remove the A/C compressor last night. I found that the two bolts that hold the compressor into the bracket will not clear the clutch pulley. Do you have to remove the clutch pulley before you can remove the bolts? Anyone get the bolts out without having to do that? Here's a pick of the setup. BTW, I got this from Pick-a-part for $75. Not a bad deal.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
09-09-2009, 12:02 PM | #10 |
Location: Sunny, Florida, some might call it South Alabama
My dad is running the serpentine setup off a 89 4.3 and it's working great on his 283 with vortec heads.
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
09-09-2009, 01:08 PM | #11 |
There should be a flat spot on the head of the bolt, just rotate the bolt until you get to the flat spot and pull it out.
1972 Chevy Blazer 1997 GMC Sierra 2009 Chevy Tahoe |
09-09-2009, 02:07 PM | #12 |
Yep, I had found the flat spot but it still wasn't enough to clear the edge of the pulley.
09-09-2009, 03:04 PM | #13 | |
resident oilfield trash
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
