Old 07-22-2009, 05:38 PM   #1
Relish
Relish's Avatar
Header question?
I a looking at getting these summit brand headers, part number Summit SUM-G9006. Does any one know if i will have to modify the clutch linkage with these headers. Also does anyone know if i would have ground clearance issues with these headers by lowering the truck 3 inches in the front and 4 inches in the back. Any help will be greatly appreciated.
Relish is offline   Reply With Quote
Old 07-22-2009, 06:04 PM   #2
69GMCLonghorn
69GMCLonghorn's Avatar
Re: Header question?
I can't help you on the lowering thing, but in terms of clutch clearance, I had no issues whatsoever. You just have to make sure you give them all the necessary details of your truck (engine, trans, manual, P/S, etc) so they give you the right ones.
They are great headers, especially for the price!
69GMCLonghorn is offline   Reply With Quote
Old 07-23-2009, 09:16 AM   #3
Relish
Relish's Avatar
Thanks for the help 69gmclonghorn
Old 08-11-2009, 01:42 AM   #4
truckguy_69
truckguy_69's Avatar
What size reducers come with these headers?
truckguy_69 is offline   Reply With Quote
Old 08-11-2009, 12:16 PM   #5
Relish
Relish's Avatar
2.5 inch reducers come with these headers.
Old 08-11-2009, 12:23 PM   #6
Gumby'sC20
Gumby'sC20's Avatar
just to confirm, yes, they are 2.5 inch reducers.
Gumby'sC20 is offline   Reply With Quote
Old 08-11-2009, 12:55 PM   #7
truckguy_69
Thanks just wanted to know before i ordered them and they will clear the z-bar?
Old 01-08-2011, 08:50 AM   #8
68longhorn
68longhorn's Avatar
A lil update on relish's truck. We put the headers on and the threaded rod of the clutch linkage made contact with the header. I cut between a 1/4 to 1/2 inch off and problem solved. All in all they fit good. As expected with all aftermarket pieces a lil tweaking was needed.
68longhorn is offline   Reply With Quote
Old 01-08-2011, 01:52 PM   #9
cajun chevy
cajun chevy's Avatar
Relish, these headers should fit my 72 c0 ,307v8, 4 speed standard? I have headers on it since I bought the truck but don't know the brand and would like to replace them soon. Wonder if the ceramic headers #SUM-G9006-9 are worth the extra money?
cajun chevy is offline   Reply With Quote
Old 01-08-2011, 05:28 PM   #10
Relish
Relish's Avatar
cajun chevy they should fit but you may have to modify one of the primaries or the clutch rod to fit them. as my brother 68longhorn stated we had to grind down the clutch rod a little
-dd: 1971 c10 307/3ott 3/5 drop
-future project: 1967 chevelle convertible 283/4spd
Old 01-09-2011, 10:12 AM   #11
68longhorn
68longhorn's Avatar
cajun, I have the summit ceramic coated headers on my caprice and the coating started flaking within the 1st year. They've been on the car 4 years and still there, just not much coating left.
Old 01-09-2011, 09:22 PM   #12
cajun chevy
Thank for the info. Probably will go with the painted headers instead of the ceramic coated.
