07-22-2009, 08:33 PM | #1 |
Not too old to learn
After many years finally getting going
Here it's been 5 years of a combination of procrastination, time, working on other projects ........ya I know blah blah
Well damn it! I'm serious Frames done .A arm bushings installed , brakes rebuilt ,power steering box in ( had old ram assist ) Painted cab . Rebuilt t400. Installed crate 350 with stock ram horns. My plan is to make it back close to stock as possible and drive it. Here is a few pics. Only thing that was a stumbling block is the pulleys. Read a lot about all the combinations for these engines, but I found a correct power steering pump pulley and now need to get the water pump 2 grove and crank 3 groove.
1968 C10 a way to long restoration. |
07-22-2009, 08:40 PM | #2 |
laying low
Re: After many years finally getting going
You've got er going the right direction now.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
07-22-2009, 10:03 PM | #3 |
are you running short or long water pump? i might have what you need depending on whether its short or long.
I called my stockbroker last week and asked him what I should be buying .......... he said "Canned Goods and Ammunition". |
07-22-2009, 10:10 PM | #4 |
Tot Roddin'
Nice looking project, good luck with the rest of the build!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
07-22-2009, 11:25 PM | #5 |
A short pump with power steering, so need a 3 groove crank and a 2 groove water/alt/ac
07-23-2009, 03:42 AM | #6 |
Looks good so far really like the blue
70 SWB STEPSIDE 70 BLAZER 09 challenger |
07-23-2009, 06:24 AM | #7 |
+1 on the color!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
02-09-2011, 01:23 PM | #8 |
Got going again. Started to mock up and gets some new parts.
Went down to Classic Industries 20% off sale Saturday, picked up glass rubber, new fender emblems and a bunch of little items. Repaired steering wheel and painted it body color. Installed head lights with new adjusting screws and plastic nuts as well as new springs. Stripped and painted radiator mount. Painted fan shroud,and valve covers after removing the plug wire holder built in at factory. Engine is a new 350 crate 290 hp with HEI. Also mock up radio and old style AM/FM cassette radio. Here is where I screwed up. Went to a lot of trouble to get some nice original Ram Horn manifolds,and had new pipes made up just to find out the crate 350 requires 2 1/2"exhaust. Found out the manifolds are 2" . Hope this won't choke engine down too much.
1968 C10 a way to long restoration. Last edited by 8door; 02-09-2011 at 03:30 PM. |
02-09-2011, 01:28 PM | #9 |
Here some pics.
02-09-2011, 01:53 PM | #10 |
Moderator
looks good neighbor! i am in riverside also.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
02-09-2011, 01:57 PM | #11 |
What?
Looking good! +1 on the color as well.
Where you at in SoCal? I'm in the Temecula area.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
02-09-2011, 02:17 PM | #12 |
Just up the road in Riverside.
02-09-2011, 02:22 PM | #13 |
This is the truck when I got it.
The second owner purchased a few years ago from original owner. I have the original protecto plate along with an owners manual,and Cal black license plates.
02-09-2011, 02:29 PM | #14 |
Who's got steelies?
Very nice work. What blue is that you painted your cab? What did you paint the rams horns with?
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
02-09-2011, 02:47 PM | #15 |
Moderator
do you need a horn button? i noticed yours is missing
02-09-2011, 03:27 PM | #16 |
Yep, it is sitting on top of dash you can see the edge of it just left of the wheel. I just stuck the wheel up for the picture, still have a few things to do with the power steering box before the steering is set.
02-09-2011, 09:12 PM | #17 |
Do you have an extra ? I am looking for a shift pointer?
02-09-2011, 09:19 PM | #18 |
Moderator
i have an extra 67/68 horn button. the only pointers i have are for tilt columns.
02-09-2011, 09:21 PM | #19 |
Grandpa in the rustmobile...
Cab looks GREAT!!
Ya gonna restore that dash bezel/guages too!?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
02-10-2011, 12:19 AM | #20 | |
The manifolds are not painted I just bead blasted them, but will apply a coating called Calyx it is a brush on material that resists heat and will be darker color.
02-10-2011, 12:23 AM | #21 | |
I will be searching for methods to do it, any suggestions ?
02-10-2011, 12:29 AM | #22 |
this truck looks awsome and i think i speak for all the guys when i say we need more pics!
02-10-2011, 12:51 AM | #23 | |
VA72C10
It will cut down on peak HP but won't hurt it too bad. If you're really worried you can always sell them to someone to recoup your investment and look for some headers/other exhaust...
Looking for a 67-72 swb or blazer project in or around VA. |
02-10-2011, 08:37 PM | #24 | |
turbo mufflers, and go back a few feet on the 2' pipe already built and install a step up. Then run 2 1/2" to mufflers. Gases expand and actually pull exhaust similar to the two stroke expansion chambers. Not knowing what the formula is, I'll just experiment and see what happens.
03-09-2011, 03:53 PM | #25 |
Messing a little more with the 68, but stopped to build a one truck garage for it.
There are other pics of it but here is exterior. Past few days I have been dry fitting parts in storage for so long, I forgot how they go together More wiring to sort and finnish engine, should be able to fire it soon. Note to moderator: should this thread be moved to "Build section" ?
