Old 07-22-2009, 09:38 PM   #1
gammamaniac
LMC Passenger Mirror '66
Hello,
I recently purchased a passenger mirror for my '66 from LMC. It came with screws to attach it to the door, but no nuts. In looking inside my driver's side door at the mirror mounting, there are nuts on the inside of the door, but I don't really see how it would be possible to get a hand/wrench in there to hold them while the outside screws were tightened. Just thought I'd check to see if there is something I'm missing, or if the nuts are welded inside the door or ?
Richard
gammamaniac is offline   Reply With Quote
Old 07-22-2009, 11:18 PM   #2
jbgroby
jbgroby's Avatar
Re: LMC Passenger Mirror '66
They should be factory tack welded on several sides.
jbgroby is offline   Reply With Quote
Old 07-22-2009, 11:36 PM   #3
LILRED66
LILRED66's Avatar
The driver side has a backing plate with factory weld nuts...welded to it. The passenger side has the same backing plate, but it does not have the weld nuts, so you will need a nut to back up the oval head machine screw. I have done this by taping a length of dowel rod to an end wrench with the nut taped to it, to hold it in place through the hole in the door shell behind the door panel.
LILRED66 is offline   Reply With Quote
Old 07-23-2009, 07:35 AM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
tonys idea sounds good, the key would be to have 2 people and a good light.
you might be better off pulling the window, and vent window for better access...
Old 07-23-2009, 07:39 AM   #5
jason65
Registerd User
jason65's Avatar
We drilled the holes for mine and put trick nuts in it. The hardest part was getting the location just right.
jason65 is offline   Reply With Quote
Old 07-23-2009, 11:26 AM   #6
apachedaddy
apachedaddy's Avatar
I guess i was lucky my passenger door had the backing plate with the nuts allready on it. All i had to do was remove the screws that plugged the holes. When i bought it there were ( i'm guessing here ) tow mirrors on it. The kind that mount to the top of the door and next to the small mirrors holes. Just had to weld up the old holes because it looked as if they used self tapping bolts on the bottom.
apachedaddy is offline   Reply With Quote
Old 07-24-2009, 03:00 AM   #7
Vernski
Some were lucky they had nuts attached to the plate, mine did not on my 65 GMC. There was no mirror on the passenger side, i'm talking about the stock ones. Someone had put the most ugly coast mirrors they could find on both sides they went to the scrap heap. Finding the plate under the door skin was anything but a cake walk. I finally took the window and vent window out[not easy if things are rusted] then you can see in there a little better at the plate no nuts as I said befor but had holes drilled in the plate. Got a scribe up in there at the closet hole and pushed up on the scribe in the center of the first hole to mark it. I used a small drill bit in case it was not the right spot, but looking at the plate it was centered. Drilled it out smaller than a1/4 by 20 tap tap out the hole and you have one hole done put the screw in and locate the other two the same way. Take you time and don't get in a hurry, I did finally put nuts on them, but I don't think you really need them I just like insurance.
One thing I noticed after putting the window&vent window in you can't see out the passenger side mirror very good the vent post is in the way. There needs to be someway ti extend the mirror shaft a few inches? Any Ideas Guys? Thanks Vernski
Vernski is offline   Reply With Quote
Old 07-24-2009, 11:28 PM   #8
Captainfab
60-66 Nut
You could get a piece of DOM tube the correct size and tap the inside the correct thread pitch for the mirror head stud. Thread that onto your mirror head and then attach to the mirror arm. Of course somewhere there you'll have to cut it to the appropriate length......
Old 10-01-2011, 10:38 AM   #9
MisterC
MisterC's Avatar
This site is Amazing! Everytime I need some information and I think of making a post, I simply do a search. Not only has the question been asked, but it's always been answered by our great members already.
Thanks all so much!
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
