07-22-2009, 11:08 PM | #1 |
need pictures
I am in need of pictures and info got a 72 blazer with 396 and no alternator or power steering brackets I have a short water pump and single grove pulley on pump and double grove on crank. can you post some pictures so I can figure out what I need to find if someone has these parts for sale I would be interested.
07-22-2009, 11:58 PM | #2 |
Member #1049
Re: need pictures
here is a set of the alternator brackets on Ebay for the short water pump big block that are correct for what you need (not mine)
http://cgi.ebay.com/ebaymotors/67-72...Q5fAccessories I do not have any pictures of the power steering.. hopefully another member will chime in with some.. |
07-23-2009, 10:06 AM | #3 |
Re: need pictures
thanks for the info
07-24-2009, 06:26 AM | #4 |
Re: need pictures
Your kind of on your own there due the 396 not being stock, it could be most any combination of bracketry.
I'd do a web search looking at big block chevy info and decide from there what your running and what you might need to make it work. |
07-24-2009, 09:32 AM | #5 |
Re: need pictures
What you need is a set of brackets and pulleys for any 65-68 car with bb or pickups thru 72. All used the short water pump set up. 72 trucks actually had a 1 year only upper alternator bracket which is HARD to find! But the 71 and older trucks and 65-68 car upper bracket will work fine and be easy to find, new or used. I will try to get some pics up of the setup on the engine. Short water pump bb also used the remote p.s. reservoir.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
07-24-2009, 11:37 AM | #6 |
Re: need pictures
does this help man. let me know if u need more
07-24-2009, 11:42 AM | #7 |
Re: need pictures
got ahead of myself
07-24-2009, 05:20 PM | #8 |
I'M TRUCK CRAZY!
Re: need pictures
I think that is a long pump.
I forgot we were talking about a BB. I have no idea. Last edited by LOW DOUGH; 07-24-2009 at 05:21 PM. |
07-24-2009, 10:14 PM | #9 |
Re: need pictures
Yeh that is a long pump thanks anyway
08-02-2009, 07:21 PM | #10 |
Re: need pictures
Do these help?
