Old 07-23-2009, 01:20 AM   #1
tim21391
tim21391's Avatar
quick question
here it is at 1 am.. and i dont wanna pull truck outta garage to figure this out.. i got blinkers working..idk about rear because bed aint on.. but they work fine.. question is.. how to i get them to light up with the headlights..im thinking i missed a ground.. is that the culprit? and if i did is it driver or pass. that i need to look at
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 07-23-2009, 01:41 AM   #2
lowbuck72
lowbuck72's Avatar
Re: quick question
more than likely if your blinkers are working then you dont have a ground issue....... without going out to look at my own truck i would say you have a problem with the headlight switch, or possibly a blown fuse...
lowbuck72 is offline   Reply With Quote
Old 07-23-2009, 01:44 AM   #3
The Big Green
Re: quick question
Hmm, I have a '67, and mine don't come on with headlights. Mine are blinkers only, they come on without headlights on, but headlights on and parklights off. I always ran their hot wire to a hot wire on the headlight. My guess would yours are either like mine or there's a ground off, but if they are on with the parklights only then yours may be like mine. I don't know what wires you took off, did you miss something if you took some wires off? Some cars don't use them with headlights, and some do.
The Big Green is offline   Reply With Quote
Old 07-23-2009, 02:19 AM   #4
red71c10
The Red Menace
red71c10's Avatar
Re: quick question
On some older vehicles the park or running lights go out when the headlights come on. It's one or the other, either the park lights are on, or the headlights are. This is more common to vehicles with 6 volt electrical systems, but I'm not sure when it was done away with.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 07-23-2009, 02:59 AM   #5
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: quick question
my 68 is the same way and I thought something was wrong, but maybe not...
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 07-23-2009, 05:41 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: quick question
begining in 68, the parking lights were required per federal DOT to stay on with the headlights.
on to the original question.... what exactly are you trying to do, you said your blinkers work fine... but you want them to come on with the headlights....
is 'THEM' talking about parking lights... or turn signals?
Old 07-23-2009, 06:23 AM   #7
big_al_71
big_al_71's Avatar
Re: quick question
for what it's worth the side lights (Fender/bedside) come on with my headlights and stay on all the time. If I pull the switch to the first spot those lights come on and if I pull it all the way they still stay on. If I turn the turn signals on the respective light from whichever side will blink accordingly including the bumper lights.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
