07-23-2009, 03:05 PM | #1 |
Mejor Que Nada
is it possible?
Is it possible to swap my 1969 swb body to a 1990 chasis? Without alot of trouble.
The only thing that separates "Dreams" from "Reality" is TIME and MONEY!!! |
07-23-2009, 03:26 PM | #2 |
Never Ending Projects
Re: is it possible?
Is it possible? Yes. Without a lot of trouble? No.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-23-2009, 03:34 PM | #3 |
Re: is it possible?
And why would you want to?
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
07-23-2009, 03:35 PM | #4 |
Re: is it possible?
Sounds like a lot of welding, hammering and swearing. Have to connect the steering column, brakes, all the brake lines, fuel lines, etc lines, radiator/fan, shifter, a/c, heater, wiring, custom gas tank, fuel filler, bumpers, and anything else that passes from the body to the frame.
07-23-2009, 03:38 PM | #5 |
its all about the +6 inches
Re: is it possible?
wheel base needs modified, the frame needs flattened/home made body lift...
it's doable, but not practicly. |
07-23-2009, 03:45 PM | #6 |
One of the First
Re: is it possible?
If you need a 69-72 SWB frame, I'm sure there is few in your area, search through the classified section...
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
07-23-2009, 03:48 PM | #7 |
Mejor Que Nada
Re: is it possible?
69 it 2wd 90 is 4wd
07-23-2009, 05:13 PM | #8 |
I'M TRUCK CRAZY!
Re: is it possible?
Why
07-23-2009, 05:31 PM | #9 |
Mejor Que Nada
Re: is it possible?
07-23-2009, 05:40 PM | #10 |
Mejor Que Nada
Re: is it possible?
refer to post 445 of show me some pics thread, this is the only reason why
07-23-2009, 07:18 PM | #11 |
Re: is it possible?
Dude, dont get all irritated. You asked questions. You got answers.
07-23-2009, 07:23 PM | #12 |
Re: is it possible?
JW? How do the frames on the late 70's model vehicles interchange with ours?
07-23-2009, 10:13 PM | #13 |
Mejor Que Nada
Re: is it possible?
not irritated at all just saying why not?
07-23-2009, 11:51 PM | #14 |
Re: is it possible?
The same reason you would not steer a car with your feet, just a bad Idea. Nothing is close between those years except the # of wheels. A much better Idea would be to find a 1987 4x4 and swap trans/tranfercase and axles to your truck. or buy a 67-72 4x4 frame to put your cab on. JMO
1969 Short Stepside 1969 4 WD Suburban 1970 1 Ton Dually....Misfit oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door |
07-24-2009, 12:12 AM | #15 |
Keep Your Nose Clean
Re: is it possible?
I though I saw the guys from powerblock start a project like this but with a ford. Check it out, it may give some clues as to what challenges to expect.
07-24-2009, 05:17 AM | #16 | |
It's alsways something.....
Re: is it possible?
I love my 2000 Z71..lots of power and great ride, yada yada and 16mpg on a 4x4 there are wrecked donor trucks out there that would be great candidates for the swap |
07-24-2009, 09:44 AM | #17 |
I'M TRUCK CRAZY!
Re: is it possible?
This truck?
I can't see were it says it is on a 90's frame. The truck looks good. Are you talking about this thread? How about some pics of 67-72 Trucks Post 445?? |
07-24-2009, 09:46 AM | #18 |
I'M TRUCK CRAZY!
Re: is it possible?
Infact it's not on a 90's frame unless they did a solid axle swap.
So, it makes me wounder if I am talking about the same truck you are. Post a pic of it if this isn't it. We love pics!!!! Last edited by LOW DOUGH; 07-24-2009 at 09:47 AM. |
07-24-2009, 12:31 PM | #19 |
Mejor Que Nada
Re: is it possible?
I know it is not a 90's frame i was just looking for options I have a guy here interested in my boat and he has a 90 4x4 he was thinking of trading i am just waying my options.
