Project 7dos
Interior IDeas...??
I have a new CD player to put in my truck....Where can i put it, to maintain the Good looks of the interior, without building a console
Ideas are very appreciated..Is the Roddoors.com Headliner with cd player pod any good?? Thanks Jason ![]()
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
Project 7dos
and what the heck is a DIN mounted stereo....
THis says it needs a standard DIN mounted stereo???? Roddoors.com
Pronounced "Pew-al-up"
I believe that DIN means that there is a knob on each side of the deck, and it will fit into our stock cutouts!
I cut mine though and put a nice new one in, and it looks sweet!!!
Classic GM Trucks of Washington Club Member 1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's, Power Locks, Truck Photos |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
It is just the opposite. The DIN opening is the one that is rectangular without knob shaft holes.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
Dreams are free
try the glove box,
have you seen the steering wheel horn buttons with controls, this would let you put it any where under the seat etc, I'm gonna cut my dash most likely
'68 swb fleetside originally w.i.p '68 member since 1-01 w.i.p = ( work in progress ) |
Thanks for correcting me... I knew it was one way or the other, but didnt mean to steer anyone wrong.
So Many Ideas, So Little Money
yeah DIN is the small rectangular size, double DIN is jsut that, a rectangle that is the smae size as stacking two decks...
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
faster, faster, faster
A din cradle is the rectangular sleeve the head unit slides into. There are single din stereos like most of us have, and there are double din stereos that are the size of the stereos in Ford F150's. Don't worry about that, your's is a single din unit and will work fine, but I would use a carbide bit and a Dremel to cut the dash. That way it is a very clean cut.
I'm going to Law School, wanna debate? It's good practice. |
Recovering Truck Driver
Here's what I did, it' makes it easy to steal, but if you get creative, you can box it in. I'ts made out of a 4" strip of channel alluminum that I found in the junk.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
More hobbies than money!
I have factory buckets and plan on putting it in the center console. The glovebox would be a good place also, but I don't think it will fit if you have factory A/C. I don't, so not sure about that. I personally don't like the headlinner deal, seems to invite people to "look what I got, you want it?"lol
'70 cst10/swb 350, 3 on the tree, factory buckets. '70 GMC lwb 350/350 ps,pb '72 c-10 lwb 350/350 a/c, ps, pb '72 Blazer project |
I was going to mount my CD changer in the glove box but I would have had to cut out the back of the box to get it in. I bought the kind with all the controls in the radio that would mount in the stock holes. I ended up putting the CD changer under the seat on the passenger side. This worked good for my Suburban.
'72 Suburban 4X4 "Save the Earth, kill yourself" |
