Old 07-24-2009, 08:10 AM   #1
eastcoastcivil
Trailing Arm Question
Are the trailing arms for a 1/2 ton the same size and fit as a 3/4 ton? Or is there a difference in the two?
If your not living for something, your dieing for nothing...
Last edited by eastcoastcivil; 07-24-2009 at 08:20 AM. Reason: I guess I can't spell. lol
eastcoastcivil is offline   Reply With Quote
Old 07-24-2009, 08:26 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Trailing Arm Question
Same size and fit, the only difference is that the 3/4 ton arms have a stiffener built into the rear where the "U" bolts go through.
LockDoc
Leon
Old 07-24-2009, 08:27 AM   #3
eastcoastcivil
You wouldn't happen to have a pic would you?
Old 07-24-2009, 08:40 AM   #4
big_al_71
big_al_71's Avatar
I have new rear early classics trailing arms coming next week and my stock ones are coming off I could take as many picts as you might need. If no one posts any I can do it for you next week when I take them off.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 07-24-2009, 08:45 AM   #5
my67chevytruck
Under Construction
my67chevytruck's Avatar
you want pics of the 1/2 or 3/4 ? I attached a pic of the 3/4, you can see the stiffener plate lockdoc referred too
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 07-24-2009, 08:46 AM   #6
eastcoastcivil
Awesome, that would be much appreciated.
Old 07-24-2009, 10:09 AM   #7
eastcoastcivil
In the pic it almost looks like there is a plate on the bottom of the arm too. Much appreciated, thanks for the pic.
Old 07-24-2009, 01:51 PM   #8
SCOTI
SCOTI's Avatar
There is.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-24-2009, 01:53 PM   #9
Hart_Rod
Hart_Rod's Avatar
It is and it's longer. It runs about 3/4s the lenghth of the trailing arm, back to frontl.
Hart_Rod is offline   Reply With Quote
Old 07-24-2009, 02:14 PM   #10
mclairmo
Sounds like we should all be running 3/4 ton trailing arms then. They should be much stronger and resist pulling apart better.
mclairmo is offline   Reply With Quote
Old 07-24-2009, 04:09 PM   #11
Gumby'sC20
Gumby'sC20's Avatar
haha...I broke my 3/4 arms
Gumby'sC20 is offline   Reply With Quote
Old 07-24-2009, 04:53 PM   #12
Hart_Rod
Hart_Rod's Avatar
Subjecting them to 40 years of salt doesn't count........
Old 07-24-2009, 05:13 PM   #13
Gumby'sC20
Gumby'sC20's Avatar
Actually, the truck was only in NY for about 4 yrs so far, the rest were Kentucky years. But,...the salt up here is super potent. (I think they have it on performance enhancing substances.)
Old 07-25-2009, 05:23 PM   #14
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Has anyone tried the CPP Tubular control arms? That is a good looking setup in the catalog...
chevyguy_72 is offline   Reply With Quote
Old 07-25-2009, 05:33 PM   #15
SCOTI
SCOTI's Avatar
They look decent. I personally like the AirRide Tech tubular truck arms better vs. CPP's part tubular, part plate version. ECE's square tube arms are also very nice....
That being said, they don't do anything a stock OE truck arm can't do.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
