Old 07-24-2009, 01:11 PM   #1
Ryan6838
what parts?
I picked up some spindles, calipers and disks of a 73-87 pickup. What parts do i need to make them work on my 68 c10? I heard that i can use my arms i just need a few parts.
Ryan6838 is offline   Reply With Quote
Old 07-24-2009, 01:45 PM   #2
SCOTI
SCOTI's Avatar
Re: what parts?
  • Lower BJ's for a 73-87
  • Upper BJ's for 73-87
  • Draglink & tie rods from a 73-87 or tie-rod to spindle adapters
  • Master cyl from a 71-80
  • pwr booster from a 71-72 (if power brakes)
  • Prop valve from a disc brake equipped truck: 71-72 (if mounting @ the master cyl) or 73-80 (if mounting @ the splash apron in the engine compartment)
  • Hard brake lines from a disc brake equipped truck: 71-72 (if mounting @ the master cyl) or 73-80 (if mounting @ the splash apron in the engine compartment)
  • The brake 'push' rod that connects the pedal to the pivot linkage on the firewall may need to be extended (my manual drum brake 68 required extending the rod when I swapped to 73-80 power discs)
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-24-2009, 01:50 PM   #3
Ryan6838
Re: what parts?
Thanks for the help. Also where can I get the tie-rod to spindle adapters
Old 07-24-2009, 02:08 PM   #4
SCOTI
SCOTI's Avatar
Re: what parts?
Check w/one of the board supporting vendors or try ECE or CPP.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
