Old 07-24-2009, 02:35 PM   #1
mikey531
mikey531's Avatar
Top Radiator Hose
The top hose on my 69 GMC 350 was made by splicing a piece on to reach the radiator. What hose is the correct one, and where can I get one !
Mike
mikey531 is offline   Reply With Quote
Old 07-24-2009, 02:45 PM   #2
mclairmo
Re: Top Radiator Hose
Any parts store should be able to get you the correct one unless your radiator is not original and has the top hose connection in a different location than oem. You can also use a wire coat hanger to mock up how the hose should be routed and to the proper length and then try to match that up to different hoses at the parts store that might work. You can also use a universal fit flex hose, though they look like crap to me.
mclairmo is offline   Reply With Quote
Old 07-24-2009, 03:06 PM   #3
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
I got mine at Auto Zone. The stock one. I used to run an ugly flex hose.
LOW DOUGH is offline   Reply With Quote
Old 07-24-2009, 03:28 PM   #4
BIG69GMC
BIG69GMC's Avatar
I had a hard time finding one myself, had to get it from napa. it was for a '71 or 72 350 2wd, unless you have the two piece hose, which autozone had those.
BIG69GMC is offline   Reply With Quote
Old 07-24-2009, 03:57 PM   #5
mikey531
mikey531's Avatar
I already tried NAPA, Autozone, and Advance Auto. NAPA even let me go look but nothing was close LOWDOUGH do you remember the part number? I also had them look at 71/72 350 It is frustrating as they don't want to look up anything in a book just on the computer.
Old 07-24-2009, 04:01 PM   #6
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
hmmm let me look. I found it on the computer. I work there part time.
Let me see. I think i am remembering corectly.
Old 07-24-2009, 04:09 PM   #7
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
i looked at Auto Zone online for a 71 Chevy w/ 350. Upper Rad. Hose
part number: XL-114 for the Kelly Springfield / Hose (Upper)
Part number: 60715 for the Goodyear / Hose (Upper) (this one would more than likly be a special order)
I also just looked up your application (69 GMC C10 / 350). It shows to be the same one. (like i thought they would realy be different)
I can't believe they can't find it in there system.
PS: I hate looking in books. Hell, I don't even know were most of them are. That's probably the case with your stores. Books are a pain.
Hope this helps
Old 07-24-2009, 04:22 PM   #8
drunkbus
New Member
drunkbus's Avatar
Gates Hoses Upper 20827, Lower 20694
Napa Upper NBH 7459, Lower NBH 7463
I recently bought new upper and lower Gates hoses using these numbers and they fit perfect. Don't have any experience with the Napa ones.
drunkbus is offline   Reply With Quote
Old 07-24-2009, 04:30 PM   #9
El Jay
Gone to greener pastures
I'm pretty sure I got mine at CarQuest. That's where I my nearly all of my parts.
The number on the hose is EBP D1 80MH 46.
I would avoid using a flex hose if at all possible. They can put undue stress on the radiator neck(s)
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 07-24-2009, 04:43 PM   #10
mikey531
mikey531's Avatar
The hose they looked up was only 23 inches long. Ok I think I figured it out. I don't think the hose needs the piece they put on. This is what I have, I just put in the Radiator today. THANKS EVERYONE !
Old 07-24-2009, 05:15 PM   #11
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
looks like the same hose.
Old 07-24-2009, 06:00 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
your motor is moved back to the inline 6 position, which is the same as the 4X4 position. If you get a hose for a 4 wheel drive, it'll work fine.
