07-24-2009, 02:41 PM | #1 |
Rear Axle Under Trailing Arms
I was thinking of moving my rearead under the trailing arms to give me some added lift. Has anyone done this? I am most concerned about the perches welded to the bottoms of the axle tubes. I don't want to have to remove the old perches and then re-weld them to the top of the axle tubes for fear of warping the axle tubes. Any thoughts?
07-24-2009, 02:48 PM | #2 |
Re: Rear Axle Under Trailing Arms
it would bolt up but it would extreamly throw off the pinon angle ive never seen any1 do it u would have to weld new perces on to the axle
07-24-2009, 03:24 PM | #3 |
I figure I can mock it all up and then rotate the front of the axle up a little prior to final welding to correct pinion angle. Of course, I would also measure for correct angle prior to final welding.
07-24-2009, 03:33 PM | #4 |
Don't forget to relocate the shocks. How are you going to get the front end up?
'72 cheyenne super step, '05 long bed gmc |
