Old 01-07-2003, 10:56 PM   #1
breeh
Recovering 67-72 Addict
breeh's Avatar
Transmission ID
Does anyone know if all of the TH350 cases for a 4x4 had a "K" on them? Will a car TH350 work in a 4x4 without the tailshaft? Thanks for the help.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 01-07-2003, 11:44 PM   #2
6869704X4
If this helps. My T350 case was shot. The trans guy took all my 4x4 guts and put it in another T350 case.
I guess the key is the output shaft. And I think thats the first part thats put in.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 01-08-2003, 01:07 AM   #3
breeh
breeh's Avatar
thanks
Old 01-08-2003, 03:07 PM   #4
outlaw
Lightbulb
If I am not mistaken there are 3 tail shaft sizes a short, long and a medium I do believe that the medium tailshaft is the one for the 4x4 but not absolutely sure I hope this helps you out
outlaw is offline   Reply With Quote
Old 01-08-2003, 08:41 PM   #5
Beast388
Suburbans RULE!
Beast388's Avatar
Breeh,
I don't think all 4X4 TH350's were K cases. The original (I think) TH350 in my Suburban was not a K case.
A few years back my TH350 went south on me. Upon teardown, I found that the case was junk. I located another TH350 used in a 2wd with the short tailshaft. I swapped all of the 4X4 guts as well as a rebuild and shift kit into the 2wd case. This setup has survived quite well behind the healthy 388 stroker in my truck.
The 4X4's don't use any tailshaft at all. The main case bolts directly to the transfer case adapter.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 01-08-2003, 09:14 PM   #6
6869704X4
I think we are mixing terms. The 4x4s dont have a tail housing. They do have an output, or, tailshaft. The length of the tailshaft would be determined by the application. 4x4 no housing, or long or short tail housing. Like some caddys had the super long tail housing.
Old 01-08-2003, 11:49 PM   #7
breeh
breeh's Avatar
Thanks for the correction. No tailhousing is what I meant.
Old 01-09-2003, 10:02 AM   #8
6869704X4
Hey breeh, got a question for ya. Where was that K on your trans case? I never knew there was difference in the cases.
And, nobody Ive asked knows what that C6 on my bell housing means.
Old 01-09-2003, 10:46 PM   #9
breeh
breeh's Avatar
There is no "K" on my 350 case but the 700R4's that I have have "K's" on both sides about 2" tall cast into the case up near the bell housing portion of the case.
