07-24-2009, 11:55 PM | #1 |
Saginaw Type PS pumps
I have a few questions about these pumps.
How can I tell if I have a press fit or keyed pump? Can I adapt one that was on a SBC to a BBC with only a bracket change? If I have a press fit how do I get the pulley off? Thanks for any input and pics are appreciated!
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys 1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers 2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers, 2009 Acura MDX |
07-25-2009, 06:41 AM | #2 |
Watch out for your cornhole !
Re: Saginaw Type PS pumps
The keyed pump will have the center shaft with threads sticking past the pulley with a nut on it.
The pressed type will have the pump shaft flush with the edge of the pulley with no nut retaining the pulley. You need a pulley puller to get the pressed pulley off.
07-25-2009, 09:23 AM | #3 |
Here is the press on type sorry don't have the bolt on pic
08-13-2009, 05:44 PM | #4 |
I have thistype of pump off a sbc, will it fit a bbc just by changing the brackets.
08-13-2009, 06:55 PM | #5 |
You didn't say what you are working on. (truck i'm guessing) long water pump or short water pump. Fwiw I recently finished a 67 camaro with a bb. It had the older "round" looking pump/reservoir combo. Looks like the ones used on these older trucks. The pump was from a small block and was used on the bb with a different bracket. However the camaro has the pump/reservoir combo bolted to the engine for all applications. Unlike the truck and chevelle which used a separate pump and reservoir on the bb.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
08-13-2009, 11:14 PM | #6 |
A bolt on pulley is alot more user friendly.
I BELIEVE IN JOHN 3:16 |
