Dual Tanks - Fit a suburban with running boards?
I have a 31 gallon tank in my suburban now but I want a little more range. I know that they had 40 gallon and I see them sometimes but can I just put a dual tank set up from a trunk into the suburban (it has running boards).
I want one for just the passenger side and will just run an electric pump from it to my primary tank (make a t-connector hose for the filler tube and splice it into that, not the actually tank) in the rear for quick transfer if I need the extra range for a long drive. I only ask because I see these dual set-up for 50 bucks all the time, and I don't think it would be too hard to hook it up - just wanted to see if it would fit. |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: Dual Tanks - Fit a suburban with running boards?
Not possible,
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
