Old 07-25-2009, 09:44 AM   #1
31-5window
Fan shroud
I have 72 blazer basket case has 396 when I got it motor was in but hitting fire wall so got some info off the board here moved cross members up 2 inchs everything is going together. But now what are the fan shroud options is there a shroud that will work or do get rid of stock fan go to electric fans?
31-5window is offline   Reply With Quote
Old 07-25-2009, 09:57 AM   #2
turp mcspray
turp mcspray's Avatar
Re: Fan shroud
Get a 2wd bb shroud. Sometimes used ones come up or you can buy a new one.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 07-25-2009, 05:54 PM   #3
31-5window
Re: Fan shroud
Okay thanks for the info. 2wd that much shorter?
Old 07-25-2009, 06:06 PM   #4
turp mcspray
Re: Fan shroud
If you mean front to back (from radiator to firewall) yes, WAY shorter.
Turp Mcspray
Old 07-25-2009, 06:40 PM   #5
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
Re: Fan shroud
Scott (Turp Mcspray) is right on on that deal, 4x4 shroud is 9" deep and a 2wd shroud is about 5 1/4" deep.
Later---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Old 07-25-2009, 07:14 PM   #6
turp mcspray
Smile Re: Fan shroud
Later---DAC
Out of curiosity I measured my 2wd big block shroud and it is 4 3/8" deep.
On my truck I moved the engine forward 2" from the small block location and with a factory water pump,pulley,and clutch fan set up (borrowed from my buddys 2wd big block truck for mock up), the fan set perfectly in my shroud.
Turp Mcspray
Old 07-25-2009, 07:48 PM   #7
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
Re: Fan shroud
Sorry, Scott I mistakenly gave a measurement of a small block 2wd shroud, before I realized you specified BB.
Later---DAC
Old 07-25-2009, 07:58 PM   #8
turp mcspray
Re: Fan shroud
Later---DAC
No problem, I just figured the more measurements to use for reference the better!
Turp Mcspray
Old 07-26-2009, 12:29 AM   #9
31-5window
Re: Fan shroud
Thanks guys
