Old 01-07-2003, 11:42 PM   #1
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Fitting stock steel wheels on a 4x4
I have tried every salvage yard around for a set of 15" stock steel 6 lug 4x4 rims with no luck, joesjunk has a set off a 2 wheel drive but says they wont clear the caliper on the front, [wheel will not turn when bolted down] can the caliper be ground down enough to make these fit? anyone else had any luck making these fit without using a spacer?
BLAZERMAN is offline   Reply With Quote
Old 01-07-2003, 11:56 PM   #2
pickupman
pickupman's Avatar
I may have some 6-lug disc wheels, will have to check tomorrow. I do not believe you can grind enough off the caliper to make them work. Bill
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 01-08-2003, 12:46 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
A buddy of mine put some washers behinde a set of 2 wheel drive rims going onto an 84 K5 once. I didn't like the idea, but it did the trick.
Old 01-08-2003, 12:46 AM   #4
Longhorn Man
Old 01-08-2003, 05:36 AM   #5
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
You cannot grind enough caliper to make the wheels fit. I tried it on a 79 Caprice Classic once that I used for a derby car, by the time I got the wheel to fit, 1 application of the front brakes, which were the only brakes on the car and the caliper was shot, so I derbied it with 1 front brake.....WOO HOO!!
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 01-08-2003, 11:37 PM   #6
Longhorn Man
That's good for making U-turns in the mud anyways. :d
Old 01-08-2003, 11:49 PM   #7
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Why won't 6-lug ralleys off 4X4 work? Or maybe you just don't like them? I like those original 4X4 plain wheels with the small stock hubcaps, but they sure are hard to find...at least in 8".
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 01-09-2003, 12:21 AM   #8
teeitup
Just like to part out trucks!!
teeitup's Avatar
Rob, what happened to the 16's you got from me, you decide to go with 15's? Have you tried Armstrong's tire in Muscotah, Ks. They have ALOT of used rims and I'd bet with all the farmers around they surely have 15's in 6 hole. Good luck Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 01-09-2003, 07:33 PM   #9
BLAZERMAN
BLAZERMAN's Avatar
Pickmup, rallyes are what I have now and just wanted to go with the stock look on this truck.
Randy, I decided not to go with the 35x16s, I bought a set of 33s and thats why I was looking for stock 15" wheels, thanks for the tip on Armstrong tire, I called them this morning and they have a good set of 15"x6" 6 hole wheels from a mid 70s 4x4 so I am going down saturday to get them.
Old 01-09-2003, 07:40 PM   #10
72addict
I have a set of stock 72 blazer wheels for $75 + shipping from 48854
1957 Cameo
72addict is offline   Reply With Quote
