Old 07-25-2009, 06:16 PM   #1
Gene
Gene's Avatar
NP203 Question
Ok, so I hate to be "that guy" who asks all the obvious questions about 4 wheel drives, but i'm to the point in my build where I want to make sure that I have all the correct parts for my truck. I'm pretty sure that the NP203 did not come in a 67-72 truck? Am I right? And I know that originally they were a full time 4wd transfer case right? Ok, so here's my problem. I'm researching trying to figure out what transfer case I have and after looking at many pictures of various cases I decide that I have a NP203(22 inches from front of case to rear). But I read that there is a part time upgrade that is available for these to make them work like a NP205. So i'm working the levers on the side of the case and one lever has three positions, one locks the front and rear together, one is neutral, and one seems to just power the rear? The other lever has 2 positions which i'm assuming is High/Low? So does it seem to you all that I have a transfer case that has been modified to part time 4wd? Thanks!
Gene is offline   Reply With Quote
Old 07-26-2009, 11:32 AM   #2
Fubar
Fubar's Avatar
Re: NP203 Question
Does your front axle have hubs to lock or unlock? If so then it most likley has a part time conversion kit in it. If you put the hubs in the free position and the t-case in hi range (not hi-loc) and the truck still moves then it has been converted.
Fubar is offline   Reply With Quote
Old 07-26-2009, 11:37 AM   #3
Fubar
Fubar's Avatar
Re: NP203 Question
Here is a good article on how to convert a 203 with a few pics that could help you tell if you have a np203 or not. http://www.4wheeloffroad.com/howto/47538/index.html
Old 07-26-2009, 05:58 PM   #4
Gene
Gene's Avatar
Re: NP203 Question
Yeah, it has lockout hubs, but this transfer case didnt come with this truck frame. I did some trading for it back when I first started the process. All I know is that I thought the NP203 was full time, and mine has a selection where the front output does not turn but the back does?
Old 07-26-2009, 07:10 PM   #5
onlyifihadachevy
Re: NP203 Question
look on the tag on it above the front output it has the model numbers and gear ratio on it.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 07-27-2009, 12:32 AM   #6
70 beast
Certified Hobbiest
70 beast's Avatar
Re: NP203 Question
i had a 203 with a part time kit in my 70.
on my levers it had high lock, high, neutral, low, and low lock, and the other was for 2wd and 4wd.
me being the college edu-macated idiot that i am, gave the 203 to a buddy that was going to use the case in a doubler when i swapped trans. but i did get the shifter assembly off it
70 beast is offline   Reply With Quote
Old 07-27-2009, 09:13 AM   #7
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: NP203 Question
Gene, I would sell it and get you a 205. They are fairly easy to come by still, and I bet you could pick one up for a couple bones. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 07-27-2009, 04:34 PM   #8
Gene
Gene's Avatar
Re: NP203 Question
Wanna buy a NP203 Trevor?
Here's my case, I didnt see a model number or a tag above the front output shaft? Just a number stamped on the flat part above it (K8M08)??
Old 07-28-2009, 12:04 AM   #9
willett
Another Day, Another Dollar
willett's Avatar
Re: NP203 Question
my 203 is fulltime, but i have locking hubs.
perhaps you could give that a go?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
