HeLp PlEaSe
i was driving last night and when i hit a bump my head lights strobe'd and then went out as well as my stereo. and didn't come back on. although my running lights still work and all other power. just no head lights and stereo, any ideas what could have happened? thanks.
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388 |
Big Red - Now its a SWB!
Re: HeLp PlEaSe
did you check fuses? this is the only thing I can think of because if it was the headlight switch or the high/lo switch it wouldn't bother the radio. Good luck!
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
Re: HeLp PlEaSe
ya, fuses seem to be fine, also i thought it might be the head light switch but it is sending power and i can switch between high and low but still no head lights.
![]() Join Date: Sep 2005
Re: HeLp PlEaSe
did the head lights blow??? i'vwe head a bump and blown both of mine before
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Re: HeLp PlEaSe
i dont think so but im gonna pull em tonight and see.
Re: HeLp PlEaSe
just take a voltmeter to the plug at the back of the buylb to see if you have 12v if so either bad bulbs or bad ground connection
Re: HeLp PlEaSe
sounds like a ground wire popped loose.
Re: HeLp PlEaSe
well i have HID headlights, lot of wires and ballasts ect. . . but i did pull em and placed halogen bulbs in and they turned on, found two wires that fried and welded themselves to my battery tray. gonna replace those and get replacement HID kit from the warranty on them. thanks for everyones help. question now is to either go with the new "10K deep blue" or "12K Deep Purple" what do you guys think?
Re: HeLp PlEaSe
Purple is my vote.
Re: HeLp PlEaSe
