Old 01-08-2003, 01:54 AM   #1
landon4421
Life is Good !
landon4421's Avatar
Question about front axles ?
The '67 C20 I just picked up has a closed nuckle front axle.
Don't know if that is right or not, wanted to know the + & -'s for that type of axle ?
Dose anyone know? Thank you Landon
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 01-08-2003, 01:59 AM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
It means that you can only run drums on it. If you want disks on the front, you will have to swap out to a 71 or newer axle. Don't know what else to tell you except that they work fine if maintained. So do the drum brakes if adjusted right. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 01-08-2003, 05:24 AM   #3
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
closed knuckles are tough as nails, but the turning radius kinda sux
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 01-08-2003, 05:44 AM   #4
MightyFine69
MightyFine69's Avatar
It is most likely a Dana 44 HD, which is what I have in my 1969 K20. I have had my truck for about two years now with no trouble until about two weeks ago. I had the internal u-joint on the drivers side break on me. I haven't fixed it as of yet. Other than that I've heard that they are good axles.
1969 3/4 ton 4x4
33's with no lift, gotta love it!
A man and his truck, it's a beautiful thing.
MightyFine69 is offline   Reply With Quote
Old 01-08-2003, 07:03 AM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
In the 44HD closed knuckle, supposedly the u-joint is stronger than the 73 and newer 297x u-joint.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-08-2003, 11:43 AM   #6
OLDCHEV4X4
OLDCHEV4X4's Avatar
I never had a enclosed knuckle frontend, but i read in "4wheel and off road" that they dont work well with lift kits. Has any body else read this?
Randy
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 01-08-2003, 02:06 PM   #7
Yukon Jack
Post Whore
Yukon Jack's Avatar
I haven't heard of them having problems with lifts. Mine is doing fine. Like stated, the turning radius sucks and of course gets worse with bigger tires that you just gotta buy after the lift.
Mine will go bye bye someday so I can have disc brakes and something stronger.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-09-2003, 06:15 PM   #8
landon4421
Life is Good !
landon4421's Avatar
ttt
I was thinking about turning it into a super stock pull truck. It is '67 C20 4X4. That is why I was asking about the + & -'s of the closed knuckle front end.
And If I should ever get around to making this pull truck thing happen I will post pic's. I must get my truck done first.
Thanks for all the input guys!!!
Old 01-09-2003, 09:24 PM   #9
Pont
I need another Barley Pop
Pont's Avatar
The closed knuckle I had in my 67 worked just fine. The only reason I could see to get rid of it (which I did) is to install a later model for the disc brakes. I still have mine, Dana 44 6 lug 4.10 gears. If you want to make the trip up from Hollister, you can have it.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 01-09-2003, 10:57 PM   #10
alta-aj
Closed knuckles leak and wear
The 69 I have had a closed knuckle front end and over time and a lot of bush miles the "balls" on the ends of the axle housing where the felt seals go wore out (about a 1/8" groove worn in them). Consequently, I can no longer properly preload the felt seals and therefore the lube leaks out of them. When I did the frameoff, I replaced the front end with one from a 72 with disc brakes - imo, much better.
alta-aj is offline   Reply With Quote
Old 01-10-2003, 01:21 AM   #11
landon4421
Life is Good !
landon4421's Avatar
Pont, Wish I would have known that in October when I drove up to washington to get my frame from Frank. Thanks alot thought, Kind of a long ride for one axle. Landon
Old 01-10-2003, 01:37 AM   #12
breeh
Recovering 67-72 Addict
breeh's Avatar
If one is not enough to inspire you, I will give you one too! I am about to take one to the salvage yard. I heard that the mudrunner guys like them because of the closed design but I don't know if that is true.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
