![]() Join Date: Jul 2009
help with production numbers and vin break down on 70-72 blazers
I need help trying to find out production numbers on 1970 - 1972 chevy blazers. I was also looking for info on how to break down the vin numbers on them. If anyone knows any web sites that would help it would be greatly appreciated. The sites that I have found all say different thing. Don't know what ones are correct. Is there a way to tell a factory 2wd blazer from a 4wd converted to a 2wd by looking at it or were they all the same body?
Big Block
Re: help with production numbers and vin break down on 70-72 blazers
CKE is 4x4, CCE is 2wd.
Big Block
CKS is 6cyl 4x4, CCS is 6cyl 2wd. CKE is a v8 4x4, CCE is a v8 2wd. Just look at the first 3 letters and you got it.
Old School, New Style
Factory 2wd blazers will be coil sprung in the rear. The frame rails bow out for the upper spring seat. 4x4's have straight frame rails and are obviously leaf spring setup. If you see a 2wd blazer that has leaf springs it is definitely a conversion. Its pretty easy to tell by just looking at the frame and suspension.
Or you could just look at the vin ![]()
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck Last edited by Long Roof; 07-26-2009 at 07:03 PM. |
