Old 07-26-2009, 02:53 PM   #1
rhodog77
rhodog77's Avatar
Urethane Bushings for s10 swap
Hey Guys, Anyone know who has the best price on the urethane cab bushings for the s10. I found some on jegs for 69.99. Having a hard time finding them anywhere else. All I need is the cab bushings. Thanks for any help!!
http://www.jegs.com/i/Energy+Suspens...4130G/10002/-1
"Get Busy Living or Get Busy Dying"
1970 P10 Stepvan
rhodog77 is offline   Reply With Quote
Old 07-28-2009, 11:51 AM   #2
BlueJeep
BlueJeep's Avatar
Re: Urethane Bushings for s10 swap
That might be about the best you'll do.
I didn't want to use the s10 ones on mine since they're so big and bulky, so I'm using Energy Suspension Jeep CJ-5 bushings. They were around $27 and are 2" diameter, 1/2" hole, and 11/16" thick. Much more compact.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 07-29-2009, 07:44 PM   #3
rhodog77
rhodog77's Avatar
bluejeep,
thanks for the info. I went ahead and order the set from jegs. The pix on the jegs website only showed the top bushings however when I got them (next day......quick service from FDX GROUND) the set came with upper and lowers for the cab as well as the radiator mounts. They are a perfect fit, well worth the money. I recommend these to anyone doing the s10 swap. I am reusing all the hardware so the tight fit is great.
thanks again!
1970 P10 Stepvan
