Old 07-26-2009, 05:47 PM   #1
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Seat Belt Solutions -- Anyone use?
Here's a link to www.seatbeltsolutions.com from their truck page. Only black is available for bench seats at this time, so just curious as to whether anyone has ever used them?
http://seatbeltsolutions.com/_wsn/page7.html
Member Nr. 2770
Old 07-26-2009, 07:52 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Seat Belt Solutions -- Anyone use?
Haven't used them, but would be interested in some if they are priced right??.....saw some 3 pt universal belts on Fleabay for $85 shipped....for what it's worth!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-26-2009, 08:26 PM   #3
mclairmo
Have not used them, but make sure you go with 3 point belts. These look like they do not bolt into the factory holes. You will have to drill holes to mount the retractors. The reason the one's from Brother's and others are so expensive is that they do not require drilling and merely bolt into the stock holes using custom made application specific brackets. I used an expensive custom made kit for my 67 Camaro and it was easy to install and feel very safe. For my 68 C10 I am temporarily using junk yard 3 point belts from a Volvo and made my own floor brackets. However, I will eventually go with a custom kit like Brother's sells once I get the truck 100% done.
mclairmo is offline   Reply With Quote
Old 07-26-2009, 09:10 PM   #4
Sinister
Between Trucks...
Sinister's Avatar
Here's the ones I'm running: https://www.classicparts.com/prodinfo.asp?number=28-071
Had to take a dremel to them a little bit to work with the factory bolts. Buckle side is a tad short if you have to move your seat forward, but I'm 6' tall so not a problem.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 07-26-2009, 09:59 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Juliano's has 'em too. But I've also read of folks using S-10 shoulder harnesses. Reckon it comes down to what you can fit and be comfortable.
Member Nr. 2770
Old 07-27-2009, 01:40 AM   #6
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
I also use the Classic Parts 3 point belts and they went in OK but like Sinister says the buckle side (center) is barely long enough to buckle. Also they come in several colors. (I got green LOL)
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
