Old 05-19-2002, 08:08 PM   #1
mark25
Post 15x8 or 15x10????????
going to buy a set of American Racing Torque Thrust II's, and going to run 275/60/R15 BFG Comp T/A's, which rim width would look better??? 15x8 or 15x10??? will a 15x10 clear on the front with that big of tire???
this on a '72 1/2 ton 2wd.
'72 C-10 Cheyenne Super, 402/TH400, Bucket Seats, tilt, tach, AM/FM & shoulder harnesses and a ground up restoration
mark25 is offline   Reply With Quote
Old 05-19-2002, 08:14 PM   #2
mikep
Used to have a truck
mikep's Avatar
Post
I used the same tire on a 69 camaro (4.30 gears in a narrowed nine inch) with 15x8's and got the impression that 15X10's would have been too wide. Its got 305/50 Euro TA's on it now with 15X10 welds and theyre sized pretty good for the tire.
No truck :-(
mikep is offline   Reply With Quote
Old 05-19-2002, 08:30 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
I have 15 X 9 1/2 on the GMC...275/60's fit on there perfect. nice flat foot print. A good tire dealer should be able to tell you the facts.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
E-mail longhornmail@yahoo.com
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
Old 05-19-2002, 08:58 PM   #4
69 longhorn
Post
I have 275/60/15s on 8" ralleys,& they print ok. I think they could be on a little wider wheel(8 1/2-9" should be optimum,from the charts I have seen),but I also feel that 10" is a little wide for that size tire......69
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 05-19-2002, 09:32 PM   #5
bluzman2004
Post
I've always been partial to the 15x15s on my 69.
69 Chevy ProStreet, Low and wild. Check it out http://y42.photos.yahoo.com/bluzman2004
78 Corvette
rturnpaugh@compcams.com
bluzman2004 is offline   Reply With Quote
Old 05-19-2002, 09:34 PM   #6
Zkast
Zkast's Avatar
Post
I'm running 15x8 (205/60R15)on the front and 15x10 (295/50R15) on the rear.
I just liked the look. doesnt make the tires last long not being able to rotate.. but hey, they have lasted me 4 years already.
Pictures and more...
piston@zkast.com
'71 LWB
350/350T, PS/PB
Special options? Yes, RUST... Need some?
Webmaster/Team owner
www.zkast.com
Garrett - Olathe, Kansas
Zkast is offline   Reply With Quote
Old 05-19-2002, 09:56 PM   #7
Longhorn Man
Post
rotate...bbah! I find that just gives me 4 bald tires instead of two!
Columbus Ohio
Old 05-20-2002, 04:42 AM   #8
Tim Christian
Tim Christian's Avatar
Smile
I have 15x10's with that tire on the back and they fit fine. Me personally would not run 10's all the way around on a 2-wheel drive. If I was going the same size all the way around it would be 8's.
67 GMC Stepside(UNDER CONSTRUCTION)
67 GMC Custom
67 Chevy C-30
Tim Christian is offline   Reply With Quote
Old 05-20-2002, 06:08 AM   #9
BW72
Post
I have 15X10 on the front of my 72' and I have no clearance problems.
72' Cheyenne, 2-1/2 exhaust, 350 with 268 comp cam,
BW72 is offline   Reply With Quote
