Old 07-26-2009, 08:16 PM   #1
ozman3803
motor mount and manual bell housing position ques???
Ok I have a 70 swb 2 wheel drive. I assuming that it had a inline 6 with the muncie 4 spd. I have been having troubles finding the clutch linkage assembly. I finally found the linkages out of a 70 3/4ton that is two wheel drive. I was in a hurry and forgot to ck out where the postion of eng and bell housing were. It did have a two piece driveshaft though I noticed. Of course I put it in today and it is still coming up short to the shift fork. It's about 4 in short or so, looks like it might have to move the bell housing up to next holes (if thats correct?). If that is the case, looks like a new drive shaft if going to be needed. What is going on here, anybody have an answer for me or even better some pictures. Sorry I don't have any pics, but if needed maybe I can get some loaded up from my phone this week. Eng mounts are in the rear position currently.
ozman3803 is offline   Reply With Quote
Old 07-27-2009, 07:03 AM   #2
JimKshortstep4x4
Re: motor mount and manual bell housing position ques???
If you are using the I-6 engine stands with a V-8, that could account for the difference.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-27-2009, 05:40 PM   #3
Jurassic-1
Jurassic-1's Avatar
I changed over a I-6 for a v8 but it was an automaticI left it in the rear holes but the fan shroud was too short so I used a 4X4 shroud. The V8 is in the forward holes and I think it uses the same mount. If you are short by 4 inches and do not want to mess with engine position you should have a threaded hole on the engine block which is located about even with the bell crank position on the frame. The ball should be removable on the 6 clinder bracket and should have the same threads as the engine block. Be sure to check the width between the engine and frame so that your bellcrank( cross shaft) will not fall out.
Jurassic-1 is offline   Reply With Quote
