Old 07-26-2009, 11:17 PM   #1
Triple6Goat
Triple6Goat's Avatar
60-66 manual steering box rebuild kit?
I have a 1962 chevy c10 2wd and I need to know who sells rebuild kits for a manual steering gear box so I can get rid of some slop.
-Thomas
Triple6Goat is offline   Reply With Quote
Old 07-27-2009, 02:56 PM   #2
Heater63
Heater63's Avatar
Re: 60-66 manual steering box rebuild kit?
Did they use recirculating ball type in '62? You can redo those for cheap. I don't know about a "kit" to rebuild...maybe they existed 30 years ago, but I doubt there is much demand now.
This is from my memory, I am not an expert on this: I redid my '63 years ago, and basically there are just bronze bushings that are standard sizes and you can get them in the diameter and thickness you need from a bearing supply house, and cut them to the length you need. Drive out the old with a brass punch. You can make a gasket for the cover plate out of sheet gasket material from the parts store. If you have wear on the balls or the tracks, you may need oversized balls . I think I saw an article in a mag in recent years where they sent a manual box to someone and followed the rebuild. Search for it on the web.
Good luck, and don't loose any of the balls.
292 + TKO500
Heater63 is offline   Reply With Quote
