Old 01-08-2003, 07:58 AM   #1
wxman1
H Pipe
I'm thinking about a set of Flows for my 69 C10.
When I went to the Flowmaster website, they state
that they highly recommend an H pipe for all
dual exhaust applications. Anybody know why?
Is anyone else running flowmasters without
the H pipe?
Jim M.
Mt Juliet
wxman1 is offline   Reply With Quote
Old 01-08-2003, 08:11 AM   #2
Old Chevy
Old Chevy's Avatar
Thumbs up
If you put the H pipe in the right place, its free torque, improved scavenging, very slightly more subtle exhaust tone, added rigidity to the exhaust system.
Cheers
Richard
Broken Arrow, OK.
1977 Corvette, ZZ4 Crate, new interior, new suspension, new driveline, you get the picture, (new project / daily driver)
Old Chevy is offline   Reply With Quote
Old 01-08-2003, 08:22 AM   #3
crazy longhorn
Fabricate till you "puke"
I would reccomend an H or X pipe in any dual system, the x is new tec , but a little harder to fit to the chassis. They are basically a balance tube, that lets the pipes draw from either side to help with the out of sequence pulses in the firing order. The "balance pipe" will give more response in the low & mid ranges, without hurting top end power. They also mellow the ex note,& give it a more "tuned" sound. they are also said to pick up some milage.......i couldnt say on that(my foot is too heavy!)
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-08-2003, 08:59 AM   #4
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
If you do go with a H pipe have them put one in that has flanges so that it can be removed for trans and drive line service.
Denny
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 01-08-2003, 11:24 AM   #5
Low69CST
I have an X pipe on my truck, motor really sounds good, not sure if its the pipe or the mean cam i stuffed in it. It impressed my dad. He had one put on his 87 4x4.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 01-08-2003, 12:33 PM   #6
barn9
Half a bubble off!
barn9's Avatar
No dual exhaust should be without it, it's a good thing!
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 01-08-2003, 12:53 PM   #7
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Here is a picture of our Performance EX exhaust system installed under a 68 Short Bed Chevy 2WD with T-400 transmission. You can see it would be a tight squeeze, but I believe the tranny could be removed with the exhaust in place.
http://www.classicheartbeat.com/exaust.htm
WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 01-08-2003, 01:08 PM   #8
Jefe
Jefe's Avatar
I am running 2 1/2 inch pipe with dual flowmaster and no H or X pipe..dumped right before rear tires. Sounds real good.
Douglas.
Jefe is offline   Reply With Quote
Old 01-08-2003, 03:10 PM   #9
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I wished my exhaust was longer... It's turned down right under where the carrier bearing is... Hey wes do you guys sell just he x portion of the exhaust?
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 01-08-2003, 03:19 PM   #10
Classic Heartbeat
Yes we do. We call that section the Street EX. If you click on the link provided it will show you pictures and prices.
http://www.classicheartbeat.com/cata...%20adapter.htm
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 01-08-2003, 07:00 PM   #11
DennyB
DennyB's Avatar
Thats pretty trick WES.
whats the internal volume at the pipe intersection as compaired to the volume of each pipe (2 1/2" pipe for example).
Denny
I.M.O.M,W,J&C
Patriot Guard Rider
Old 01-08-2003, 07:11 PM   #12
Classic Heartbeat
As I remember the whole that is cut in each side is about 2" X 3" then both sides are welded together. WES www.ClassicHeartbeat.com
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 01-10-2003, 12:35 PM   #13
DennyB
DennyB's Avatar
Neat idea..I like it!
Denny
I.M.O.M,W,J&C
Patriot Guard Rider
