Old 07-27-2009, 09:00 AM   #1
gcburdic
Restoration Virgin!
gcburdic's Avatar
One Man Brake Bleeders
Anyone got any recommendations for one-man brake bleeder kits???
Saw this on at Harbor Freight....http://www.harborfreight.com/cpi/cta...emnumber=92474
what are you using??
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-27-2009, 09:09 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: One Man Brake Bleeders
That's what I use and it works OK. I still like the old 2 person-pump the pedal method though...
LockDoc
Leon
Old 07-27-2009, 09:28 AM   #3
my67chevytruck
Under Construction
my67chevytruck's Avatar
saw this on trucks! yesterday seemed to work good..
Motive Products
Web: Motive Products
Phone: 877-59-BRAKE
-The Motive Products POWER BLEEDER(TM) is the number 1 selling DIY pressure brake bleeder. The POWER BLEEDER(TM) operates just like the professional mechanics' tool at a fraction of the price.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 07-27-2009, 09:32 AM   #4
LockDoc
LockDoc's Avatar
Motive Products
Phone: 877-59-BRAKE
Here is a link to Motive....
http://www.motiveproducts.com/
LockDoc
Leon
Old 07-27-2009, 09:50 AM   #5
fixit-p
fixit-p's Avatar
Never used them but always thought these were cool http://www.speedbleeder.com/
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 07-27-2009, 10:00 AM   #6
cdowns
cdowns's Avatar
i just pump the brakes then put a cement block on the pedal and crack the bleeder //been doing it that way no issues for the past 45years
Old 07-27-2009, 10:12 AM   #7
Sinister
Between Trucks...
Sinister's Avatar
I use a one man bleeder kit I got from Kragen. basically a plastic bottle with some hose and a magnet on it. Stick it to the frame above the bleeder and pump. Probaly cost about $5. That Harbor Freight one looks useful though.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 07-27-2009, 10:33 AM   #8
kevmic28
kevmic28's Avatar
I have the one from Harbor Freight and I am not impressed with it. Good vaccuum but the connector is not very good. Its the weakest poiny of the system. I can hear air being sucked into the tube from the connection. Seems like it puts air back into the system. Im still having issues bleeding my brakes. They work but seem soft to me.
kevmic28 is offline   Reply With Quote
Old 07-27-2009, 10:54 AM   #9
DANTIP
DANTIP's Avatar
The Motive Products works well. It's just a glorified bug sprayer bottle but has the correct parts to do a good job.
DANTIP is offline   Reply With Quote
Old 07-27-2009, 11:04 AM   #10
mr48chev
mr48chev's Avatar
Hardware store sprayer
http://www.bmw-m.net/TechProc/bleeder.htm
Take an old mastercylinder cap and rig a fitting on it and then cut the center of the gasket out with a razer knife. Put in a pressure gage if you want to but it isn't a necessity with this unit.
I have a Mity-Vac which the Harbor freight unit is a knock off of and while it gets the job done you do have a bit of vacuum leak around most bleeder screws and quite often where the hose goes on the bleeder. Still it is pretty easy to use when you are alone and need to get the job done.
I haven't made one of the units with the spray tank yet but that is in the plans.
Old 07-27-2009, 11:35 AM   #11
LockDoc
LockDoc's Avatar
I just put Teflon tape on the bleeder screw threads. It cures the vacuum leak problem.
LockDoc
Leon
Old 07-27-2009, 11:53 AM   #12
Elephanthead
I have a similar one, it seems to suck the fluid right through the lines, the rubber connectors that came with mine seem to work good, seal tight. Mine is called a mitey vac. Was 15 bucks I think. Does other things too.
Elephanthead is offline   Reply With Quote
Old 07-27-2009, 12:28 PM   #13
monte0185
monte0185's Avatar
Pump the brakes good and hard about 10 times them pull the top off the master cylinder and gravity blead the brakes in order back to front. I have been doing this for years and works like a champ and dosent cost anything.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 07-27-2009, 07:50 PM   #14
rick0312
rick0312's Avatar
I have the harbor freight one. Works good, but the litttle rubber gasket under the cap seems to leak very easy and you lose vacuum.
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline   Reply With Quote
Old 07-27-2009, 07:54 PM   #15
QKENUF4U
QKENUF4U's Avatar
MITY-VAC all the way.....
QKENUF4U is offline   Reply With Quote
Old 07-27-2009, 09:03 PM   #16
Booya
Booya's Avatar
I agree with QKENUF4U. Mitty-Vac.....
Booya is offline   Reply With Quote
Old 07-27-2009, 09:18 PM   #17
lclippard
lclippard's Avatar
http://www.harborfreight.com/cpi/cta...emnumber=92924
this is the one i have. and i use it very often at the shop. it works great. the best way to do any bleeding is when you are thru with any particular wheel, remove the vacuum hose BEFORE you close the bleeder and close it ONLY after fluid begins to trickle out. this takes care of any air that was sucked in thru the threads on the bleeder screw.
69 burb/01 yukon chassis
65 Comet Caliente 289 4 Door Sedan
99 Millenia S (supercharged) 4 Door Sedan
02 Yamaha R6
69 swb c10 http://67-72chevytrucks.com/vboard/s...36#post3799136
building with a buddy:
85 C10 http://67-72chevytrucks.com/vboard/s...94#post3708194
lclippard is offline   Reply With Quote
Old 07-27-2009, 09:27 PM   #18
BarryB
BarryB's Avatar
I have the Mity Vac version of the first HF vacuum pump, I just used it recently to bled the back brakes on the DD. Did good I actually vacuumed all the old fluid out so I now have new fluid in my system. Doing that made a bigger improvement than I would have originally guessed.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 07-27-2009, 09:46 PM   #19
lclippard
lclippard's Avatar
geoff, what are you trying to do? bleed or flush? maybe i'll give ya a hand.
02 Yamaha R6
Old 07-28-2009, 08:27 AM   #20
gcburdic
Restoration Virgin!
gcburdic's Avatar
I need to bleed my brakes.....come on over or I'll head over to your place and let's get it done!!!
Geoff with a G
