Old 01-08-2003, 08:05 AM   #1
Showme-K-20
Frontend info?
I've run across a frontend in a junkyard with a busted diff. It's a Ferd (that's what is lettered on the lockouts) and I was wondering if the rotors are interchangeable with Chevy axles? By the way, 3/4 ton 8 bolt rotors. Thought I might salvage the outer ends if I can use them. Thanks--
Bob
Showme-K-20 is offline   Reply With Quote
Old 01-08-2003, 09:12 AM   #2
Blazer1970
Blazer1970's Avatar
Pretty sure that all of the outer parts (spindles, hubs, rotors, caliper brackets and calipers) are different on a Ford than GM.
Blazer1970 is offline   Reply With Quote
Old 01-08-2003, 03:13 PM   #3
outlaw
if you want to put spindles and all other hookups on your truck use parts off of a chevy or gmc, but yes I know fords are more plentiful in salvage yards
outlaw is offline   Reply With Quote
