profeshinaly unimployed
wtf
so much stuff broke on the way to pick up my girlfriend i was driven down the road and then the speedo went out and then the blinkers stopped working...all within 10 minutes and the voltmeter in my truck wasn't even picking up a reading
"having mud flaps is like asking for a smaller trophy" |
Re: wtf
The connection from the wiring harness to the gauge cluster may have a problem. The voltmeter, turn signals, and the function of the entire cluster all depend on this connector. The speedometer is a different story as it is cable driven but it's not too hard to diagnose. First thing to check is if the cable is still attached to the back to the speedometer.
1977 GMC Sierra Grande |
Re: wtf
I would start at the same place if the dash was going haywire, but the truck was still driving fine.
It'd be alot cooler if you did
Re: wtf
Check the wiring connection at the steering column as well.
Re: wtf
Obviously you need a different girlfriend.
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Re: wtf
well i think it might be the battery cuz after driving a good bit and then trying to start my truck again it wouldn't start and by the way kieth my girlfriend thinks your a dick lmao
Re: wtf
That's ok - I have that effect on women...
Re: wtf
If you lived closer to valdosta, I could help you with alot of those small problems you are having with your truck.
Robert Olson Transport
![]() Join Date: Oct 2002
Re: wtf
forget the battery make sure your alternator is charging and the belt is properly tightened.. that is more likely the problem
yes, i do
Re: wtf
yeah, this issue deffinately sounds like an alternator issue. i had the belt come loose on one of my vehicles a few years back and it acted like the alternator was dead. the only thing keeping me alive at the moment was the momentum from going 60 mph. no lites, stereo, nothin. the only things i had were barely any headlights(but they were more like park lights) and my speedo. so check the alternator.
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
Re: wtf
well the voltmeter is after market and im hopping its an easy fix for the speedo and the reason i think it was the battery was cuz it came out of my old truck witch had problems keeping a charge but i thought it was the alternator in my old truck
I have car A.D.D.
Re: wtf
Take the alternator out and test it.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
#13 |
yes, i do
Re: wtf
an easy way to test the alternator while its still on the vehicle is to take a multimeter and check the terminal on the back. if you are getting anything less than about 13.5 volts then your alternator is going bad. even with a bad battery, the alternator should keep the system charged.
#14 |
Re: wtf
Man bro I aint got an answer for u but, lmao dude you have had some ****ty luck lately. I hope things change for u already. Keep ur head up
Its Kool to be a square ![]() 2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's 1985 C-10 ......My dream truck (under construction) 1984 k 10 Silverado...6" lift with 38.5 super swampers ![]() ![]() --- ![]() ![]() ![]() |
#15 | |
Re: wtf
man i wish i did too cuz i would love the help
"having mud flaps is like asking for a smaller trophy" Last edited by pokethesmot; 07-29-2009 at 11:52 PM. |
#16 |
Re: wtf
welp im starting the process of taking apart the dash to see if the cable disconnected
#17 |
yes, i do
Re: wtf
a relatively easy way to check the speedo cable is to disconnect it from the tranny, hook a drill up to it, and see if the drill can make your speedo needle move. a 12v coordless should be able to spin that cable fast enough to get that needle up to about 20mph or so if your cable is good. so if your cable is connected to the speedo then i would check it with the drill.
#18 |
Re: wtf
[QUOTE=pokethesmot;3437669]lol thanks man and i got my electrical system all worked out i think lol but now i just need to go out there and see whats wrong with my speedo
Speedo? Man bro why you got to tell us bout that. Men speedo's are just wrong. Ohhhhhh not that kind of speedo. N/R. ![]()
