Old 07-27-2009, 10:53 AM   #1
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Rear end noise
So i've just put my D/S back on the truck with my new combo U/J where it broke out of the pinion yoke, started her up and took it very gingerly out the drive and onto the road, I could not get it much over 15mph as a strange vibration and or whiring sound would start to come from under the truck. Had a look underneath and nothing had changed except for a small oil leak from behind the pinion yoke so I realise that means I need a new seal. But can anyone tell me what other unseen damage could have been done to the axle when the D/S broke out of the P/Y a few weeks back??
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 07-27-2009, 10:59 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Rear end noise
Well Crap Nigel!!!....Fix one thing something else goes!!!....
Not sure of the problem, but have you changed the rear end oil and gasket in awhile??.....if you do, run your fingers through the oil as it drains for any metal filings??.....Maybe something happend to the ring/ pinion when the DS broke?? (this is purely a guess!!!)
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-27-2009, 11:03 AM   #3
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Rear end noise
could the drive shaft have thrown the weight when the u joint broke? did you install the ujoint or have a shop do it. you may want to have the balance checked. is this a 2-piece d/s with a carrier bearing?
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 07-27-2009, 11:17 AM   #4
mr48chev
mr48chev's Avatar
Re: Rear end noise
Did the driveshaft get any dings in it when the cross broke? I've also seen them damaged when someone went wild clamping them in a vise to work on them.
Old 07-27-2009, 11:35 AM   #5
eightbanger
454 MAKES IT ROAR
Re: Rear end noise
Been looking through the service manual Geoff and that's what I was wondering may have happened.
If you mean the ballancing weight it is still there, I did install all this myself and double checked everything, and yes it is the 2 piece with carrier.
No I was real carefull there.
Here is a vid i've just taken....the exhaust noise drowns out the whiring sound coming from the rear end, but WTF is that terrible sound when I take my foot of the gas.
Nigel.
No more pain.
Old 07-27-2009, 12:46 PM   #6
john
member #16
john's Avatar
Re: Rear end noise
Looked like the yoke was moving back and forth in the second vid. Did you use a new crush sleeve? See if you can move it front to rear.
john is offline   Reply With Quote
Old 07-27-2009, 12:56 PM   #7
eightbanger
454 MAKES IT ROAR
Re: Rear end noise
When I was fitting the new pinion yoke tightening the centre nut the yoke would throw out forward, I assumed it did that when it engaged or something...sorry I don't know what a crush sleeve is John.
Nigel.
No more pain.
Old 07-27-2009, 02:09 PM   #8
dznucks
dznucks's Avatar
Re: Rear end noise
i agree. i think something is wrong inside the rearend. that input shaft should not move that much. one thing i notice in the "repaired" pic, is the cap of the new u-joint doesnt look like it is contacting the "tang" of the new yoke. it could be that you have a mismatched u-joint and yoke.
i had that problem before, where my ujoint was 1/8" shorter than the distance between the two tangs of the yoke. the drive shaft would slide back and forth everytime it rotated. cause a wierd vibration and crazy sound.
dznucks is offline   Reply With Quote
Old 07-27-2009, 02:10 PM   #9
john
member #16
john's Avatar
Re: Rear end noise
OK I am assuming that is a truck 12 bolt diff. Here is a link on how to set up a 12 bolt, which explains the crush sleeve.
http://www.hotrod.com/techarticles/d...ide/index.html
In your first pic it looks like there are a couple of threads sticking out of the nut. Second pic looks more like it is flush with the nut. You should not have any noticible end play in the pinion shaft. There must be some reason why the yoke tightened up before the end play was gone, burred shaft etc.I would pull the yoke back off and find the prob. before driving it. Alot of guys reuse the sleeve in a pinch by not overtightening and overloading the bearings. If the yoke is free on the shaft you will be able to tell when you come up against the sleeve to your old adjustment. Kinda longwinded hope it helps.
Old 07-27-2009, 02:18 PM   #10
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Rear end noise
Originally Posted by dznucks View Post
i where my ujoint was 1/8" shorter than the distance between the two tangs of the yoke. the drive shaft would slide back and forth everytime it rotated. cause a wierd vibration and crazy sound.
It doesn't take but a few mm of movement for a lot of sound to be generated. I'd be sure that the U-Joint is located between the tangs on the yoke w/o any room for movment. At the same time, I'd be making sure that the U-Joints are not stiff. If they are, you'll also get a vibration. What I mean is that if you hold the driveshaft and shake it back and forth, the U-Joint should flop somewhat. It may not move much, but it should move some. Sometimes, the action of pressing the U-Joint into the yoke of the driveshaft will pinch the ends of the driveshaft together just enough to keep the U-Joint from being able to freely move.
Member Nr. 2770
Old 07-27-2009, 02:34 PM   #11
eightbanger
454 MAKES IT ROAR
Re: Rear end noise
Thanks for the link to that article John....really good info. It is a 12 bolt.
I'll take it apart and do another vid, and those u/j caps are tight against the tangs it 's just not showing well in the pic.
Nigel.
No more pain.
Old 07-27-2009, 03:12 PM   #12
eightbanger
454 MAKES IT ROAR
Re: Rear end noise
Ok....new pics showing that the u/j caps are nice and snug and another showing a closer view of the centre nut on the yoke.
Hope these vids help identify the problem.
Nigel.
No more pain.
Old 07-27-2009, 03:38 PM   #13
john
member #16
john's Avatar
Re: Rear end noise
Now were getting somewhere. Just need to find out why the yoke is not on all of the way. Did the old yoke pull off hard?
Old 07-27-2009, 03:40 PM   #14
mclairmo
Re: Rear end noise
Also, be sure not to overtighten the straps holding the u-joint onto the new yoke. Most people way overtighten which can cause binding and premature failure. A suprisingly low amount of torque is specified, something like 10 ft/lbs I believe or even less. Look it up or maybe someone here knows the exact figure.
mclairmo is offline   Reply With Quote
Old 07-27-2009, 03:49 PM   #15
eightbanger
454 MAKES IT ROAR
Re: Rear end noise
Yes, it had to be persuaded a great deal with prying and a good few thumps at the back of it with the hammer. I had to use a wood block accross the front of the new one to get it down firm before I put the nut on and tightened it up.
Nigel.
No more pain.
Old 07-27-2009, 06:13 PM   #16
john
member #16
john's Avatar
Re: Rear end noise
When you get the yoke back off pull the seal and look down the splines and make sure there is no twist in the shaft. You are using old bearings, so I just snug the nut up with some locktite on the threads. The worst thing you can do to worn bearings is overtighten them. That should get it to where it was or close to before it broke.
Old 07-27-2009, 10:27 PM   #17
71 super
71 super's Avatar
Re: Rear end noise
You definitely have some extra slack at the pinion. Someone stated earlier that it looked like the nut was not as tight as previous and I agree with them. You need to locate the torque spec for the pinion nut and do that again. The nut is swedged and should not need loctite on it but if you use some use blue not red. I would also pull the rear cover and with a depth gauge check the pinion as well as the gear pattern after you retorque the pinion nut. You can do this with some white lithium grease to check the pattern. The pinion gears should ride in the middle of the ring gear and since yours is obviously an older (i.e) stock rear end there should be an existing pattern worn into the gears to go by. Definitely pull rear cover , retorque pinion nut to specs and check pinion depth with guage and your movement and noise should be gone. Good luck as this can be intimidating especially if it is your first time but it can be done.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 07-28-2009, 05:01 AM   #18
eightbanger
454 MAKES IT ROAR
Re: Rear end noise
Thanks 71 super going to do that today. I must admit I can't imagine it's just down to how tight the nut is.....remember all this happened because my d/s broke out of the pinion while I was driving and it was flailing around under there until it fell off, so i'm guessing it must have done some other internal damage.
Nigel.
No more pain.
Old 07-28-2009, 06:29 AM   #19
eightbanger
454 MAKES IT ROAR
Re: Rear end noise
Ist pic was taken when I changed the gasket and oil about a year ago...
This pic I have just taken, it's clear something major has happened....
Hopefully someone will know what might be broke....or should I just start dismantling?
Nigel.
No more pain.
Old 07-28-2009, 10:03 AM   #20
71 super
71 super's Avatar
Re: Rear end noise
Give your pinion a pull forward and rotate it again holding pressure on the pinion to the front. If the noise goes away it is in the pinion and could be solved by the correct torque on the pinion nut. Give your axle shafts a tug as well just to be sure the shafts are not broken. You can do this by pulling on the wheels to see if there is give; there should be very little to none. From the grind marks on the carrier something is loose and flopping obviously and there are not many options. I think it is the pinion being too loose but check the axles and the carrier saddles for cracks just in case.
Old 07-28-2009, 06:59 PM   #21
eightbanger
454 MAKES IT ROAR
Re: Rear end noise
I have since discovered that the grind marks on the carrier were made by the teeth on the pinion drive shaft because it seems to be able to move in and out of the differential. I am able to pull the shaft in and out which shows way too much play........ what do i need to do to correct this play? Is it the shims or can this be corrected by further tightening of the nut on the pinion yoke? You were right 71super, when i pull forward on the pinion shaft the noise does go away but it still dosnt feel that smooth when I turn the wheels.
Nigel.
No more pain.
Old 07-28-2009, 09:27 PM   #22
Phaedrus
Phaedrus's Avatar
Re: Rear end noise
Tighten pinion nut until fore / aft movement goes away and try it. If your not using an impact wrench you can tell when the crush sleeve slack is taken up pretty easily (it'll get really hard to turn the nut). Worst case you trash the pinon bearings and you need to overhaul, versus a grenaded rear end from pinon gear to carrier collisions.
Phaedrus is offline   Reply With Quote
Old 07-28-2009, 09:39 PM   #23
eightbanger
454 MAKES IT ROAR
Re: Rear end noise
Thanks Phaedrus, i'll try that cause it's got to the point were I can do no more without special tools and a lot more knowledge.
Nigel.
No more pain.
Old 07-28-2009, 09:42 PM   #24
john
member #16
john's Avatar
Re: Rear end noise
You still need the yoke to slide fairly easy on the splines or you will never know when you are adjusted right. Good luck.
Old 07-28-2009, 09:46 PM   #25
eightbanger
454 MAKES IT ROAR
Re: Rear end noise
Thanks John, and for all the advice that's been given to me by everyone......
Nigel.
No more pain.
