Old 07-27-2009, 11:55 AM   #1
FLDBRED
Small cap hei?
I took the HEI out of my son's 69 Chevelle to see if it would fit in my 1971 shortbed 4x4.It hits the firewall!Do they make a small cap HEI?Thank You!
FLDBRED is offline   Reply With Quote
Old 07-27-2009, 11:56 AM   #2
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Small cap hei?
Yes, Mallory does (SP?)
LOW DOUGH is offline   Reply With Quote
Old 07-27-2009, 12:01 PM   #3
FLDBRED
Re: Small cap hei?
WOW!That was quick!Thanks Drew.
Old 07-27-2009, 12:35 PM   #4
cdowns
cdowns's Avatar
Re: Small cap hei?
quite a few manufactures do // i've used the one from pertronics ,it uses an external coil so it keeps the original apperance with the ease of HEI
Old 07-27-2009, 05:02 PM   #5
Jurassic-1
Jurassic-1's Avatar
Re: Small cap hei?
I have a 1972 CST Blazer. I also have a HEI in it. It fit very close to the fire wall however I left the plug wire lock ring off and it fits OK. The only thing that is a challenge was the plug wire lenghth. I used the mallory universal set with angle boots. They now make a new cap for rewiring the cap so the right 4 and left 4 banks are on the same corresponding sides which would make wiring easier. Another thought would be using an 88 and up 5.7 distributor which is smaller but has an external coil. I am pretty sure it would fit. Good luck.
Jurassic-1 is offline   Reply With Quote
